Lift Kit Advice Needed
Discussion in 'Suspension' started by Jigzor, Jun 2, 2009.
  1. Jun 2, 2009 at 7:22 PM
    Jigzor
    Jigzor [OP] Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    I'm looking to have a 2.5" - 3" lift in the front and either wheelers or toy tec aal. I would figure the toytec ultimate lift would be ideal but I don't really have the cash for it. What are my other options? I can't be without the truck seeing its my daily vehicle. So I would need to know all parts or kits needed. I have never bothered the suspension with my other vehicles in the past so this is completely new to me. I want to avoid any common issues from the start, without going back and fixing it at a later date. Suggestions for available kits based on 'bang for the buck' would be helpful.
  2. Jun 2, 2009 at 7:37 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Get a set of Bilstein 5100's for the front and set at 2.5", if you want to go higher add a 1/4" top plate from Toytec (gives 1/2" of lift), thereby giving you 3". Then put an AAL in the rear, but go ahead and put some 5100's back there too. Downsouth MotorSports give forum members a break on the price.
  3. Jun 2, 2009 at 7:45 PM
    Jigzor
    Pennsylvania
    17 DCSB Silver Sky
    That would work with the stock springs? Would that improve the ride at all or just keep it stiff? that seems like a very inexpensive way to give it a lift.
  4. Jun 2, 2009 at 7:47 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    X2 to badguy.....
    That's the exact setup quote I just got from Downsouth. Not sure if I'll add the spacer. And yes it will work on stock springs.
    I'll be adding 33"s to go along with it.
  5. Jun 2, 2009 at 7:50 PM
    badguybuster
    Michael
    It is a slightly stiffer ride but WWWAAAYYYY better than if you did a 2.5" spacer lift. You may loose some alignment. You will have to have your alignment adjusted after lifting to correct any abnormalities.
  6. Jun 2, 2009 at 7:53 PM
    Jigzor
    Pennsylvania
    17 DCSB Silver Sky
    My main goal is just to have an edge, not just a stock truck. 2.5 with a 1.5 aal would be fine by me. Largest tires I would use is 265/75/16.
  7. Jun 2, 2009 at 7:54 PM
    Jigzor
    Pennsylvania
    17 DCSB Silver Sky
    Other than getting it aligned, I really shouldn't have any other surprises right?
  8. Jun 2, 2009 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Nope.
  9. Jun 2, 2009 at 8:21 PM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    A spacer like the truxxx lift or equivalent where the spacer is on the outside of the coilover, rides better than the 5100's IMO, because the springs aren't preloaded, i've had both. Never had an aal, but I did get the dakar leafs, I would highly recommend them.
  10. Jun 2, 2009 at 8:39 PM
    Jigzor
    Pennsylvania
    17 DCSB Silver Sky
    What would change that would make me need new UCAs or do I not need them?
  11. Jun 3, 2009 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lifting that high, you will loose caster. Your truck will wander. Aftermarket UCA's with aditional Caster built into them ( Total Chaos), correct for this and allow the vehicle to be aligned to spec.
