Lift kit advice
Discussion in 'Suspension' started by G.Lloyd.624, May 27, 2021.
  1. May 27, 2021 at 1:21 PM
    G.Lloyd.624
    G.Lloyd.624 [OP] New Member
    Gabe
    2013 Toyota Tacoma sr5
    Bull bar, light bar, kmc enduro wheels
    I have a 2013 Tacoma sr5 that I am looking to lift. I go camping quite often. Nothing very serious that I would need to throw a lot of money at it but a small lift will help (more with clearance) I was looking at the ready lift sst 3”. I have a budget of under or around $1000. I also looked at the ome 3” kit but can’t find much about it online. I see a lot of people suggesting the Bilstein 5100s. If anyone has any suggestions for a kit I should look into or any advice I would greatly appreciate it. Thank you in advance!
  2. Jun 23, 2021 at 6:19 AM
    Alpaca01
    Alpaca01 Member
    Their are plenty of threads here on TacomaWorld that explain suspension lifts, but I can help with what you need specifically.
    For starters, a 3" lift is not a small lift.
    Bilstein 5100s are recommended because they provide great value for a mild lift.
    Do you carry a bunch of gear? Would you like a rake look on your Tacoma or leveled?
  3. Jun 23, 2021 at 5:41 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I vote you go a complete dobinsons lift from @Crikeymike with spc ucas since you want 3 inches
    Crikeymike likes this.
  4. Jun 24, 2021 at 6:25 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Here's the full thread on Dobinsons options for the 2nd Gen's
    https://www.tacomaworld.com/threads/dobinsons-2nd-gen-tacoma-suspension-options.458013/
    A 3" spacer lift is a super common budget lift, and a lot of dealers even put them on trucks, but they can have negative effects on the stock parts, and with yours already being older, they probably won't last very long.
    @Dalegribble02 is right, a 3" lift will require new UCA's for a proper alignment and front end movement.
    The least expensive route I offer with Dobinsons is a Quick Ride Kit, which uses a spacer block and longer u-bolts in the rear to gain the lift instead of a full leaf pack, which saves over $500, but it's still $910 at a base price before adding UCA's, then $1540 with the SPC UCA's. You can see all the options here:
    https://exitoffroad.com/product/dob...toyota-tacoma-2005-2015-with-quick-ride-rear/
    Dalegribble02 likes this.
  5. Jun 25, 2021 at 7:31 AM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    Honestly I would avoid a cheap lift for clearance. These trucks have plenty of clearance for anything you'd find just going camping, I've never once had clearance be an issue(and I ran stock OR suspension for a long time) outside of technical wheeling, even then I took the stock truck up pretty challenging trails and can only think of one or two times I had to turn around due to clearance before traction or just seeming like I was getting in over my head. If you're worried about a tall rock or something just place your tires on it instead of straddling. The real benefit of a lift comes from travel, articulation and overall suspension performance.
    As others have mentioned it'll drive like crap if you don't do UCAs and at that point you're spending a lot of money for a little clearance.
  6. Jun 25, 2021 at 7:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Clearance of what exactly?
    The axle lines are the low point, and only tire diameter will lift them.
    Suspension lift can help with approach/departure angles, but is that where your problem is?
    jasmits1 likes this.
  7. Jun 25, 2021 at 7:45 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I would recommend OME as a good middle ground kit.
    Can't say that I recommend the Dakars leaf packs though; especially if you carry any weight in the rear
  8. Jun 25, 2021 at 8:04 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Im thinking, based on your budget and use, a bigger wheel / tire setup might be more beneficial.
  9. Jun 26, 2021 at 2:20 PM
    Twitch896
    Twitch896 Member
    06 dclb
    Ome lift all around with dakar leafs 17” kmc Rigid fogs
    I’ve had the full OME kit for a few years and love It. I will be upgrading now that the shocks are due, but i would def buy this kit again. I am also running jba uca with the he balljoint. A better option for uca over spc IMO.
    JC713 likes this.
