Lift kit combo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kdawwwg, Sep 5, 2010.
  1. Sep 5, 2010 at 11:13 AM
    Kdawwwg
    Kdawwwg [OP] Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    I am thinking of trying the rcd 4 1/2 in lift with 883 coils [1 1/2in of lift]
    as my sport springs have saged over a 1/2in from stock height ,i would probly only see a 4in gain with that spring,
    any thoughts ,maybe 884 coils ?cause im double cab long bed,but they are 2in of lift on a 4 1/2 lift ,would be either a sick lift:) or to much cv angle:eek:.
    only other things i could think of would be that it will mess with the valveing of the longer 5100 shock that comes in the kit, or the shock it self would now not be long enough?,
    an brake lines may or maynot work, any thing else im missin
    i all ready have light racing uca's so getting alingment with aftermarket coils would not be a problem
  2. Sep 5, 2010 at 11:23 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    If you are worried about your CV angles you can get a front Diff drop kit. If you were 4x2 you could get 4" spindles (i don't think they make spindles for 4x4)
  3. Sep 5, 2010 at 11:24 AM
    Kdawwwg
    Ken
    Draper,Utah
    forgot to mention i allready have a diff drop too
  4. Sep 5, 2010 at 11:28 AM
    krimson
    krimson Nothin
    TRD Off Road
    Ah okay, it shouldn't be that bad with the angles if you already have a diff drop... There's guys running 6" lifts with diff drops and they have no problems.
  5. Sep 5, 2010 at 11:28 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    wont work... your front drive shaft will contact the lca... the RCD spindles aren't big enough to handle much over 4.5" of lift.
    trust me we accidently had the springs on wrong during the install and everything was jacked up, UCA contacted springs, drive shaft rubbed LCA, and cv angle was ridiculous.
    I have after market UCAs too
  6. Sep 5, 2010 at 11:32 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    diff is already lowered with RCD kit...??? :confused:
  7. Sep 5, 2010 at 11:34 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    :popcorn:
  8. Sep 5, 2010 at 11:38 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  9. Sep 5, 2010 at 11:43 AM
    Kdawwwg
    Ken
    Draper,Utah
    ya i figured the diff drop that you install with a 3in kit would be removed,
    how about just a differnt spring like the stock offroad spring, or something close to stock height
    or what about a ome spacer kit i think they go up to 7/8 ,that would compensate for the 1/2 spring sag ,an get me to allmost 5in
  10. Sep 5, 2010 at 11:45 AM
    program
    program Member
    Rubicon
    what truck?
    I find it hard to believe that at full front sag all those components are going to come into contact... I'm assuming that you mean the front axles also, not the drive shaft. by saying that a 2" spring will not work on the RCD kit your saying that the kit doesn't provide 2" of down travel...
  11. Sep 5, 2010 at 12:07 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Oops I meant axles... we put the spring seat on upside down and everything made contact ucas lcas it was just a mess.... now drew02a had a 1 " spacer on the rcd kit and it worked I just think the 884 might be too much
  12. Sep 5, 2010 at 12:19 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Since the RCD kit is a knock off of the procomp kit it should be able to handle the additional lift. Depending if they kept the Procomp specs. (Not sure about the RCD spindles)
    Procomp of all the DB lifts are able to be jacked up the most, over the intended design.
    You shouldn't have UCA issues because you'll be running the LR UCA's.
    If what "solus694" is saying is true? (LCA's rub axles)
    Then RCD has a detrimental Design flaw!
    The LCA's through the full ranges of drop should NEVER contact the LCA's!
    If this is true RCD is an accident waiting to happen!
  13. Sep 5, 2010 at 12:26 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    The lca only rubbed when the spring seat was installed wrong if installing the seat upside down increases the length of the shock Assembly then that was the problem otherwise I'm wrong. Once everything was correctly install all was good
  14. Sep 5, 2010 at 3:06 PM
    program
    program Member
    Rubicon
    what truck?
    RCD a knockoff of Procomp? how did you come up with that?
