Lift Kit for 1st Gen PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by PreRun_ESH, May 11, 2021.
  1. May 11, 2021 at 12:11 PM
    PreRun_ESH
    PreRun_ESH [OP] Member
    2004 Double Cab Pre Runner
    Stock
    Any recommendations on 2-2.5" lift kit Car currently all stock tire P265/70R16 2004 PreRunner Double Cab
  2. May 11, 2021 at 12:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. May 11, 2021 at 2:37 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    ICON Vehicle Dynamics for CO's and shocks and Total Chaos or Camburg for upper control arms.
    Wait for Off Road Warehouse to have their Desert Madness sale next month.
  4. May 11, 2021 at 3:09 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I'm sorry...."car"? Break that habit homie!
    Abeyancer and Ritchie like this.
  5. May 11, 2021 at 6:46 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    We need more deets: budget, intended use, etc...
    What are your plans with it?
    Is this going to be a bro lift to match the size of your belt buckle? Or do you plan to do some off-roading with it? Will this be an "overlander", a fishing/hunting truck, daily driver, dune hucker, Baja prerunner, etc...?
    You can spend anywhere from a couple hundred bucks up to several thousand. The sky is literally the limit. The performance you get from each is vastly different, but for a daily driver there's no reason to spend several thousand for adjustable coilovers and uniball UCAs.
    Abeyancer likes this.
  6. May 11, 2021 at 6:51 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Don't you tell me how to live my life
  7. May 11, 2021 at 6:54 PM
    jbrandt
    Justin
    This is the interwebs. Isn't that what we do?
    :D
  8. May 11, 2021 at 7:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    40s n tons
    jbrandt likes this.
  9. May 11, 2021 at 7:54 PM
    PreRun_ESH
    Stock
    hilarious your right Truck!
    MalinoisDad[QUOTED] likes this.
  10. May 11, 2021 at 8:06 PM
    PreRun_ESH
    Stock
    Daily Driver, Maybe some light off-roading to get around gridlock so going over some islands in this Concrete Jungle beef it out.
  11. May 11, 2021 at 8:10 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Bilstein (spelling?) and an add a lead
  12. May 12, 2021 at 5:30 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Bilstein 5100s with eibach 3 in coils. Rear just do a shackle from toytec etc or you run a block. Add a leaf might stiffen the ride up if you like that​
  13. May 12, 2021 at 7:50 AM
    jbrandt
    Justin
    If you can spend around a grand, get the full OME kit. Your f/r springs are more than likely worn out anyway and should probably be replaced. This kit will replace all springs and shocks.
    If you're on a tighter budget, get some 5100s and a rear add-a-leaf. That'll run about $400-500.
