Lift Kit Help!
Discussion in 'Suspension' started by tylerdjefferson, Sep 5, 2008.
  1. Sep 5, 2008 at 8:30 AM
    tylerdjefferson
    tylerdjefferson [OP] Member
    Florida
    06 Access Cab
    18" Drag Chrome Wheels, TRD Seat Covers, LED Underglow, Chrome Grille Inserts
    I was going to install my front spring spacers and rear leaf myself but a friend told me it was something I can't do it myself because the spring in the front is under too much tension. Can I install a spring spacer and add a leaf on my own or should I have it professionally installed? :confused:
  2. Sep 5, 2008 at 9:26 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    You can borrow a spring compressor from autozone. What type do you have? I see no reason why you couldn't do this my yourself, I did mine but I changed the coil springs and just added a block to the rear.
    There should be some instructions with your kit, if you have a kit, mine instructions were very good from toytec.
  3. Sep 5, 2008 at 9:31 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    most spacer lifts will not need a spring compressor. get some C-clamps for the leaf springs and a friend to help spread the front control arms and your rockin and rollin
  4. Sep 5, 2008 at 9:47 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    top load spacers will need a spring compressor...
    once you get those put on the coils...you can put the coils in yourself and the aal is cakewalk
