Lift kit ideas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by That2wdTacomaGuy, Jul 30, 2023.
  1. Jul 30, 2023 at 8:49 PM
    That2wdTacomaGuy
    That2wdTacomaGuy [OP] Member
    Tacoma 2017 2WD
    What is a good route to go about lifting my 3rd Gen Tacoma 2017 2wd? I have been looking around YouTube and here to figure out what I should go with, but keep ending up at the end of a rabbit hole with no luck. Maybe I'm slow or something, but any help/ ideas please let me know! other than that, ya'll have a great day and keep on keepin on!
    I guess another question that pops up into mind now would be if I do coil over set, would i need to add any leaf springs?
  2. Jul 30, 2023 at 8:54 PM
    Bishop84
    Bishop84 Well-Known Member
    We need goals and budget.
    There's spindle lifts for 2WD tacomas, they are quite big.
    If you want to bomb along service roads a proper coil over set would be a good idea.
    Simple cheap spacer lifts work but don't drive as well as the other choices.
  3. Jul 30, 2023 at 9:01 PM
    That2wdTacomaGuy
    Tacoma 2017 2WD
    Thank you for your feedback Bishop84!
    I guess another question that pops up into mind now would be if I do coil over set, would I need to add any leaf springs?
  4. Jul 30, 2023 at 9:04 PM
    Bishop84
    Typically by now your rear springs have worn and sagged, so adding a curved new spring will only cause a temporary lift, so most replace the rear spring with an Icon or Dever set, or just simply add a 1" block for simplicity, with longer rear shocks.
    If you want a simple lift, read up on Bilstien 5100's for Tacoma's. They are the best budget lift and work with a simple rear lift.
  5. Jul 30, 2023 at 9:06 PM
    That2wdTacomaGuy
    Tacoma 2017 2WD
    [QUOTE="Bishop84, post: 28987040, member: 172494"
    If you want a simple lift, read up on Bilstien 5100's for Tacoma's. They are the best budget lift and work with a simple rear lift.[/QUOTE]
    I’ve been looking at those actually, was curious if I could even put them in a 2wd. If so I’m my sender is somewhat solved!
    tcjacado likes this.
  6. Jul 30, 2023 at 9:08 PM
    Bishop84
    2WD and 4WD are identical for suspension, you are good to go!
    It was the older tacomas with 5 lug nuts that had varying suspension. All 2005-2023 6 lugs effectively share the same bolt in suspension.
    I'd say get 5100's and a rear 1" block, or if the rear springs have had it, get a new leaf pack with 1" lift.
  7. Jul 30, 2023 at 9:22 PM
    That2wdTacomaGuy
    Tacoma 2017 2WD
    So neatoo!
    Thank you so much for your information and time!
    I’m great full, that really clears up a lot of things for me.
  8. Jul 30, 2023 at 9:53 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Another thing to consider; are you planning to add weight, haul weight, or tow?
    If so, at the least, I’d add a leaf, or better yet, a new leaf pack. If not, chuck a booth in there and roll on!
  9. Jul 30, 2023 at 10:00 PM
    tcjacado
    tcjacado Well-Known Member
    Bilstein 5100 in all four corners and a 1 inch block for the rear spring
    Set the fronts Bilstein to the second notch. You won't be disappointed. ;)
  10. Jul 31, 2023 at 12:33 PM
    That2wdTacomaGuy
    Tacoma 2017 2WD
    Eventually I’m gonna but a hitch on trucky, probably wont haul heavy things, but I do have a tent on my truck so that just adds weight with all my camping gear in the truck.
    2tons of pea gravel made my truck sag low though so hoping if I gotta do stuff like that again, it wont be as bad if I have a suspension lift.
  11. Jul 31, 2023 at 12:34 PM
    That2wdTacomaGuy
    Tacoma 2017 2WD
    I’ll definitely take this into consideration, thank you for your feedback and your time!
    tcjacado[QUOTED] likes this.
  12. Aug 6, 2023 at 11:12 PM
    That2wdTacomaGuy
    Tacoma 2017 2WD
    If I end up doing bilstien 5100, do I need to
    switch out my uca’s, and or ball joints? Still stock uca’s, but they look/feel fine.
  13. Aug 7, 2023 at 9:20 AM
    tcjacado
    No need to to change control arms or ball joints for just adding 5100's.
