Lift kit inquiries
Discussion in 'Suspension' started by Mon Leb, Apr 25, 2009.
  1. Apr 25, 2009 at 10:07 AM
    Mon Leb
    Mon Leb [OP] Well-Known Member
    St-Jean-sur-Richelieu, Quebec, Canada
    2009 4X4 SR5-TRD Sport
    Hi !
    I,m looking for a lift kit 3'' for my 2009 Tacoma.
    According to your experience, (meaning YOU did it, or got it done)
    1. Which brand is the best?
    2. Am I gonna get a real 3'' in the back?
    3. Should I go for AAL or a block installation?
    P.S. I'm actually looking for the Revtek 426 or 426A, but i'm waiting for YOUR COMMENTS FIRST before buying.
    Thanks a bunch!
    Mon Leb.
  2. Apr 25, 2009 at 10:12 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I only have experience with my 3" toytec lift. I went with the lift blocks in the rear because at the time toytec only offered that if you had the TSB done. I installed my lift and love it. I have the 884 coils up front, Now toytec reccomends the 885 for double cabs. I also have the TRD shocks all around, with extensions in the rear. All drop kits and axle degree shims.
  3. Apr 25, 2009 at 10:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
  4. Apr 25, 2009 at 10:18 AM
    jrukus
    jrukus jason r
    queen charlotte islands
    black '08 trd tacoma
    285/70/17r tires on stock rims, sirius radio
    I bought a tough country lift from suspensionconnection.com and I put it in with my dad and we installed it in about 7 hours, it would have been quicker if we had a wall mounted spring compressor, but I am really happy with the lift. It has coil spacers in the front and lift springs in the back. The front went up 3" and the back 2.75", I recommend it anyways, I know I have put it through a durability test over the last 6 months.
  5. Apr 25, 2009 at 10:31 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Welcome to the board- Your questions and bold/colored comments make it challenging just cause most folks don't have more than one lift...so I'm not going to say which is best- I ordered OME parts for mine...but haven't installed yet-so I don't know how they are.
    If you order the right parts-yes you will get 3 inches...Are you trying to keep the same rake all the way around or get it level @ ~3inches high??
    Go the AAL- Less issues on the whole. Blocks can break and worsen axle wrap...AALs tend to help with wrap and while they can break it's far less common.
  6. Apr 26, 2009 at 6:17 AM
    Mon Leb
    I don't know yet. I guess i'd like to have a real 3" in the front as well as in the back. But the more I look, the more I understand that most of the companies I saw on internet (thanks to all the people who took the time to answer me) only offers 2.25" to 2.75", not more. But I could live with that.
    Thanks!
    ML
  7. Apr 26, 2009 at 6:37 AM
    rick
    rick `
    x2
  8. Apr 26, 2009 at 7:43 AM
    Mon Leb
    Hi! Thanks for the infos. What kind of spring compressor did you use?
  9. Apr 26, 2009 at 8:07 AM
    Mon Leb
    Thanks! You guys help a lot!
    ML
  10. Apr 26, 2009 at 10:47 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    check out toytec... I love there lifts and prices. You will get a great quality ride out of the OME kit. Spacers will give you a stiffer ride.
  11. Apr 26, 2009 at 11:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I sense a little sarcasim here. Were just giveing you a friendly welcome. LOTS of different lifts out there, and youre not giveing us much info to help you. The "Best" depends on alot of things. What do you want the lift for? Looks? Wheeling? Whats your budget?
    Spacers are gonna either stiffen your ride (Preload spacers) or extend the spring/shock assembly (Top Plate spacers). THEN, you have seperate springs you can get, and different spring rates. Are you going to add a bumper? Winch? "Coilovers" offer adjustability, AND different spring rates, but have to be rebuilt periodically. THEN, If you lift near 3" in the front, Your gonna have Alignment adjust ment issues. You will loose Caster. Are you gonna replace your UCA's? Your best bet is to search around the site. See what others are running on their trucks. ASk some questions and decide what you are going for. All of us are going to help you make an educated desision.
  12. Apr 26, 2009 at 4:57 PM
    Mon Leb
    My dear Chris I'm sorry that you took it like I was been ironic and/or sarcastic. NO SARCASM HERE BUDDY! Just a guy who really appreciate the advices of you all. Quite frankly when I'm asking questions around where I live, all I get is somebody who doesn't know f$%? all, and want to sell me anything, by all means. So once again, I just want to gather as much infos as I possibly can (mainly because I haven't fixed my mind yet!) from people who actually when through the same process, and don't have anything to sell me.
    Thanks again!
    ML
  13. Apr 26, 2009 at 5:08 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Ask until you understand, we will do our best.
  14. Apr 26, 2009 at 5:44 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    x3
  15. Apr 26, 2009 at 5:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, then, What are you looking for out of the lift? Looks? Off Roading? Both? A 3" lift will throw your alignment off, and a top plate spacer can be hard on the ball joints, and possibly lead to breakage of a shock. Are you going to get different wheels? ANd what size tires are you looking to run?
  16. Apr 26, 2009 at 11:08 PM
    yamahamod
    yamahamod Active Member
    Korey
    Colorado
    06 Tacoma SC w/total chaos & King shocks
    I did the Total Chaos A arms with the king shocks totally ajustable up to 3 inches up front. Donahoe are shit.
    I added the add a leaf to the back.
    Don't forget the the axel drop spacer.
    I drive the F 'en dog shit out of mine.
    Yea that's a tundra in the picture but I posted the pic so you can see the shocks.
    Good luck
  17. Apr 27, 2009 at 6:05 PM
    yamahamod
    Korey
    Colorado
    Here are some pictures for ya. If your looking for a lift with a baha type of ride. Stilll raises it 3 inches.
  18. Apr 28, 2009 at 2:33 PM
    Mon Leb
    Thanks for the pics! I see you changed the upper control arms as well ! :cool: Did you have to do it or just wanted to?
  19. Apr 28, 2009 at 2:43 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    As far as having experience with a specific lift, I have a 3" spacer lift from Xtremetrucktoys...... and dont like it much. Makes some funny noises, induces binding, and the AAL that came with it flattened out.
    I have some OME 885 coils I'm going to swap into the front when I have enough money to buy their matching shocks and do it all in one swoop. On the rear I now have a new 1.75" AAL from Wheeler's Offroad and a 1" block and some Bilstein 5100 rear shocks extended for more flex via toytec's extenders. That setup works pretty good for me- Rides comfortably, handles loads well and works offroad well too.
  20. Apr 28, 2009 at 2:46 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    When you lift 3 or more inches it is smart to replace your UCA's, it will help out the alignment problems and what not.
