Lift Kit Install Naples
Discussion in 'Florida' started by gunit3099, Sep 14, 2022.
  1. Sep 14, 2022 at 6:48 AM
    gunit3099
    gunit3099 [OP] Member
    2022 SR5
    Anyone in the Naples area that could help install a Eibach Stage 1 on my 22’ SR5? Been looking around at some shops to do the work but the prices are insane. Don’t have the tools or the space to complete the job. TIA
  2. Sep 14, 2022 at 9:21 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    What are they getting nowadays if you don’t mind me asking? Does that kit need to use the stock top plate?
  3. Sep 14, 2022 at 9:25 AM
    gunit3099
    2022 SR5
    $640 for the kit plus $800 for labor and alignment.
    This kit is using the stock top plate.
  4. Sep 14, 2022 at 9:36 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard.
    Grey 2015 likes this.
  5. Sep 14, 2022 at 10:06 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    $800 for labor and alignment does seem steep. I guess $100 for an alignment and $700 to install.
  6. Sep 14, 2022 at 10:09 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    You should look around and see if you can find a set of top plates that way someone doesn’t have to break down your stock coilovers to get the top plates. Might be a bit cheaper.
