Lift kit issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DonM77, Jul 26, 2023.
  1. Jul 26, 2023 at 1:40 PM
    DonM77
    DonM77 [OP] Well-Known Member
    Don
    Back in 2019 I had a lift kit installed on my 2016 tacoma that was purchased from Headstrong off-road. The kit contains Bilstein 5100 shocks.
    The shop that installed the kit was recommended by several people from one of the Tacoma groups I belong to. About 15 months after the kit was I stalled my local Toyota dealer while doing an oil change discovered that the rear passenger side shock was blown. I reached out to Headstrong and they said I needed to contact Bilstein. After several months of emailing them back N forth they replaced the shock under warranty.
    Fast forward to April of this year...truck was once again in for an oil change and Toyota discovered the replacement shock was now blown and leaking. Contacted Bilstein and after two months of going back N forth sending pics of the set up Bilstein discovered that the kit was installed with the overload springs left on, when they should have been removed by the shop that did the install per the specs of the kit.
    I contacted the shop who specializes in doing lift ect...and they asked me to come in so they could look at it. The shop claims Bilstein is garbage and basically said their work was fine. The install went smooth and leveled fine at the time of install. The owner become very defensive while he was overlooking the rear end of my truck stating I shouldn't have gone with Bilstein shocks, blah blah blah
    While the owner was bashing the lift on my truck he was simultaneously measuring the wheelwell height and determined that the rear passenger side was much higher that the rest. In fact it was about 1-1/2" off.
    The owner said he'd eat the labor and remove the overload springs which Bilstein stated was the problem. I wasn't happy with that as I already shelled out $150 to have the replacement shock that was covered under warranty installed now he wants me to purchase a new shock which he called "shit" which was damaged as a result of improper installation. When I pushed back and reminded him I wasn't here for his opinion on Bilstein and that I was here to determine what the issue was he quickly whipped out his phone and ordered a new 5100 shock. I was happy with this and scheduled a day to have it installed along with having the overload springs removed.
    Here's my question and main concern with this. I do believe what Bilstein said was true, however with that said why didn't the driver side fail too? This tells me that there is additional issue related to the install that I'm not aware of. Any ideas???
  2. Jul 26, 2023 at 1:51 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have been on 5100s and never an issue, in fact my local shop never took anything out of mine. Your not getting lift from the shock. Did you buy the truck new?
  3. Jul 26, 2023 at 1:54 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    So is the issue that the lift was too much with the overload causing the shock to top out and fail?
  4. Jul 26, 2023 at 2:24 PM
    DonM77
    Don
    Yes brand new
    The 5100 shocks can handle 1" lift per Bilstein however leaving the overload springs brings it to 2" in rear causing dampening.
  5. Jul 26, 2023 at 2:27 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    The parts are good, the shop is shit.
  6. Jul 26, 2023 at 2:33 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Taco lean probably saved your driver side shock.
  7. Jul 26, 2023 at 2:42 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I got way more than 1" of lift in the rear with my 5100s. I haven't had any issues.
    Whats all done in the rear besides the 5100s?
    02Duck likes this.
  8. Jul 26, 2023 at 2:46 PM
    DonM77
    Don
  9. Jul 26, 2023 at 2:58 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Where did the overload springs come from?
  10. Jul 26, 2023 at 2:59 PM
    Pentangler
    Pentangler 24 Aces
    2022 DCSB OR 4x4
    Previous Toys: 2021 DCLB OR 2017 DCSB SR5 2006 RAV4
    My understanding is that rear 5100's don't provide any lift. Based on your link (above) there is a drop down menu for rear lifting via an AAL (add-a-leaf). Did you have an AAL installed? If so, and if the shop did not remove the overload per your request, then the info that Bilstein provided is probably accurate. FYI: Bilstein does sell a modified 5100 extended travel but I can't remember the part#. Good luck.
  11. Jul 26, 2023 at 4:07 PM
    DonM77
    Don
    Yes AAL. And per Bilstein they don't make a shock that would work with the overload springs.
  12. Jul 26, 2023 at 4:23 PM
    VaToy
    Parts Unknown
    Who added the overload springs. So the shop put them on or didn't remove them? So I'm trying to see how they got on the truck.
  13. Jul 26, 2023 at 4:32 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    OEM pack has an overload. Headstrong said remove said overload when installing AAL.
    VaToy[QUOTED] and DonM77[OP] like this.
  14. Jul 26, 2023 at 4:34 PM
    DonM77
    Don
    It's my understanding that the overload spring comes stock on the suspension and needed to be removed in order to work with the AAL lift.
    Mark77 likes this.
  15. Jul 26, 2023 at 4:36 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    On my 2nd gen I did 5100s back in 2021. Year and a half 25k miles later both my shocks blew. First one blew and the 2nd one blew 3 months later. All I had was stock leafs and a 1 inch lift block. I had the 5100s rated 0-1 inches of lift. I've been a Bilstein guys for years, but they made it a huge hassle to get them warrantied. They wanted to me to remove the shock and send it to them for evaluation. Well, what the hell am I supposed to do without a shock? Buy a new one and then get another new one in the mail lol. Screw Bilstein.
  16. Jul 26, 2023 at 4:40 PM
    V01dnet
    V01dnet The Professor
    Kansas City
    2022 Army Green TRD Off Road
    I went with Icon. Happy with them so far.
  17. Jul 26, 2023 at 4:41 PM
    fourfourone
    Next go around I'll definitely spend some coin and go with good suspension.
    V01dnet[QUOTED] likes this.
  18. Jul 26, 2023 at 4:44 PM
    V01dnet
    Kansas City
    I got lucky and married a girl who is bankrolling my truck for the sake of content creation.
    Sucker
  19. Jul 26, 2023 at 6:39 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    let’s see that pavement princess!
  20. Jul 27, 2023 at 5:48 AM
    V01dnet
    Kansas City
    Its in the shop getting a 5.29 regear and a body mount relocation done. I plan on posting new pics once the CBI duel swingout rear bumper is done.
