lift kit options
Discussion in '5 Lug' started by 808tacomas, May 22, 2013.
  1. May 22, 2013 at 11:43 PM
    808tacomas
    808tacomas [OP] Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    honestly i dont have the money to afford a lift kit rite now. so is there anything out there that can lift my truck or do i need a full on lift kit?
  2. May 23, 2013 at 12:12 AM
    DSully72
    DSully72 Well-Known Member
    Daniel
    Newport News, VA
    04 PreRunner TRD Off Road
    :facepalm:
    if you wanna go as cheap as possible, you could try a spacer/leveling kit. Its just a metal spacer that you put between the top of your shock/coil assembly up front. for the rear, you can either score some blocks or add a leafs. check out toyteclifts.com. there's also probably some "pro comp" or "fabtech" spacer and add a leaf kits on ebay as well... I don't recommend it though, better to just be patient and do it right the first time (new shocks/coils or a complete coilover assembly in the front and preferably new leaf springs in the rear). you'll also find nicer lift kits on the Toytec site as well. All pro also sells some good stuff as well. Later on you can add nice stuff like upper control arms and what not. you can also go long travel, but I don't know anything about long travel, might wanna search on that before starting a new thread though... Just tryin to bust your balls a little :D
  3. May 23, 2013 at 11:31 PM
    808tacomas
    kingrob
    oahu
    thanx bro. true ill just save up and get a lift kit. so that way everythings done correctly
  4. May 23, 2013 at 11:33 PM
    808tacomas
    kingrob
    oahu
    does toytec have lifts for 5 lug? because it says
    (Lift products will not fit models with 5 lug wheels)
  5. May 24, 2013 at 1:07 AM
    DSully72
    Daniel
    Newport News, VA
    Hm... Not to my knowledge. Perhaps fabtechmotorsports.com. You'll have to buy from a separate dealer, but check out their products. Pretty sure they have 5lug lifts
  6. May 24, 2013 at 9:23 AM
    MowTaco
    MowTaco Well-Known Member
    South Dakota
    03 GMC Sierra
    Check out the Fat Bob's kit for spacers, it's pretty common around here. I have Fabtech lift spindles in mine to keep stock suspension characteristics (spindles essentially mount the wheel down lower to lift the truck. The UCAs and LCAs and the spring/shock stay in the exact same spot)
    For the rear, you are limited to an AAL. Blocks will lower you because 5 lugs are spring under rear axles. Shackles will lower you too because 2nd gens have stupid flipped shackle mounts.
  7. May 24, 2013 at 3:08 PM
    DSully72
    Daniel
    Newport News, VA
    There ya go! shows how much i know about 5 lugs :anonymous: lol.
  8. Jun 15, 2013 at 7:16 PM
    mistahgood
    mistahgood Active Member
    Mistah
    South Carolina
    2013 Tacoma Access Cab 2wd 4cyl
    hockey pucks are cheap and do the job lol
  9. Jun 20, 2013 at 5:13 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    Check out the fat bobs lift for 5 lug. It's cheap and will do the trick til u figure which route to go. I installed mine a while ago and it's done the truck for me. I run mine with 265/75r16 and will b switching to 285s when these tires or gone.
  10. Sep 1, 2013 at 11:22 AM
    Chargin18
    Chargin18 Adult Member
    Charlie
    Salisbury, NC
    07' Regular cab DeBadged
    Stereo system, off-road lights, roll bar, HID kits, Hyperion Led Bar, 3 inch lift, custom satoshi grill, 31 10.50/R15, black rims, 5% tint, custom built headlights. paint matched grill, 1.25" wheel adapters.
    did the fat bobs lift for your 5 lug have an aal in the rear? if so, did it lift it the height it said it would?
