Lift kit or leveling help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mlaroche, Mar 9, 2014.
  1. Mar 9, 2014 at 7:39 AM
    Mlaroche
    Mlaroche [OP] Active Member
    Michael
    Saugus, MA
    TRD off road
    HID headlights HID fogs K&N air intake Bull bar After market grille 10" LED light bar Smoked tails 34% tint 4" front windshield tint
  2. Mar 9, 2014 at 8:50 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Stay away from spacer lifts. What happens with the spacer lifts is the strut bottoms out before the front suspension hits the bump stops and bends the strut. Do a search on TW and you will get all the answers about lifts. I don't have a lift on mine but reading on here will give you an education. Hope this helps.
  3. Mar 9, 2014 at 9:06 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I suggest a set of Bilstein 5100's. If you have the 4 leaf pack or the TSB leafpack on the rear, you can set the front's to 1.75" of lift, and level the truck out, and fit 265/70's front and rear, without modification or need for front and rear spacers on the wheel hubs.
  4. Mar 9, 2014 at 6:17 PM
    Trailrider
    Trailrider Member
    Austin
    6" BDS suspension lift with Fox shocks
    After doing several spacer lifts on some Toyota trucks I would suggest a lift.
  5. Mar 9, 2014 at 6:50 PM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    I had a spacer lift for a year. It was ok but ride was stiffer a little. I changed to 5100s and love it much smoother ride. If your on a tight budget and dont go wheeling spacers are fine.
