Lift Kit or Leveling Kit?
Discussion in 'Suspension' started by Logan22, Jul 19, 2011.
  1. Jul 19, 2011 at 12:32 PM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    I am going to lift my 06 double cab trd 4X4 tacoma soon. I am trying to decide what I should do to lift it. Should I get a leveling kit, if so how many inches? Or should I get a lift kit? If I get a lift kit I dont want any higher than 3 inches. Which ever one that I do, I want to be able to put 285/70R17 tires on it with no rubbing without trimming anything. I want to put the smallest lift that will fit these tires on it because I dont like a whole lot of space between the top of the tire and the top of the wheel well. What should I do? If you can post pictures of what yours looks like that would be great!
  2. Jul 19, 2011 at 12:35 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    billy 5100s all around with a AAL with elbich(sp?) coils and probably need some UCAs as well.. wa la
  3. Jul 19, 2011 at 12:50 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i recommend a full lift kit.
    if you run 285's @ 3", you will have to trim something no matter what if you are saying that you absolutely do not want rubbing.
    whether its the mud flaps, or the pinch weld, part of the plastic on the inner fender, cab mount, etc.. something will be rubbing and will need to be trimmed.
    but really, its not a big deal. you can trim away alot and it will still look good. here you can see all that i trimmed:
    stock:
    this is the after pic of the body mount chop and trimming on the inner fender well. you can also see that the inside of the fender was trimmed too.
  4. Jul 19, 2011 at 2:10 PM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    thanks for the info. It is real helpful. I like the truck. NetMonkey, are you running 285's with a 3 inch lift? Does this make a big difference on the gas mileage and also does it make your speedometer a little inaccurate?
  5. Jul 19, 2011 at 2:19 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow 4" bracket and 35s. MC rear AP front bumpers 5.29s locked
    OME lift with 885s and the dakar pack
  6. Jul 19, 2011 at 2:23 PM
    NetMonkey
    Geogetown, TX
    yes, 285's with a 3" lift.
    i went with MT tires so that dropped my mpg by about 2-3. i am getting 15-16 mpg now whereas before, i was getting 17-19mpg. (click on the fuelly link in my sig to see my mpg history).
    you can get a lighter 285 AT tire that wont affect your mpg as much as it did for me, but you can still expect at least a small drop when you go to 285's.
    yes, the speedometer was a little off. i have a scanguage that i calibrated to my gps so i can always see my true speed. at 75mph (scanguage and gps reading) the truck speedo says about 71.
