Lift kit or suspension ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spencer402, Aug 15, 2018.
  1. Aug 15, 2018 at 3:15 PM
    Spencer402
    Spencer402 [OP] New Member
    Spencer
    2016 taco trd
    I’m new to the thread and looking for a high quality lift to fit 33”-35”. I do a lot of off-roading and rock climbing and want minimal to no rub ever. I don’t want to spend money on Kings but I don’t want dirt cheap. I was thinking icon maybe stage 5-6 or old man emu any help is appreciated! This is my daily driver so superior ride quality and superior off road performance is what I want.
  2. Aug 15, 2018 at 3:25 PM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    You can fit both of those tires with no lift. Either way, lift or no lift, you’re going to have to cut plastic and chop the cab mount. I’ve had OME/Bilsteins and now Kings. There is no “superior ride” quality unless you buy a superior product.
    There’s a shit ton of threads on here for this topic and a whole section on lifts.
    kgilly and VangaSTL like this.
  3. Aug 15, 2018 at 3:37 PM
    Spencer402
    Spencer
    2016 taco trd
    Ok thank you!
    JeffP213 likes this.
  4. Aug 15, 2018 at 3:40 PM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    You will have to regear for 35s. I just went from stock 30s up to 32s and I can feel the bogging at highway cruising speeds.
    Spencer402[OP] likes this.
  5. Aug 15, 2018 at 3:43 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I have 34s. Bilstein 6112/5160. You WILL need to CMC, beat back pinch weld, trim plastic. No way around it. Doesn't matter what suspension you buy, you always want to make sure your tires will clear at full compression
    Mod fan and Spencer402[OP] like this.
  6. Aug 15, 2018 at 3:49 PM
    Spencer402
    Spencer
    2016 taco trd
    @VangaSTL hows the ride quality on road and off ?
  7. Aug 16, 2018 at 6:05 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Its not a Mercedes. I removed my sway bar so I have to really take it slow around corners, 34s really suck out the power but I'm used to it. Don't expect it to get up and go like it does on OEM tires. I'll probably re-gear next tax season or get the OV tune at least. Off road it works well, don't really have anything to compare it to. The shocks haven't snapped in half yet so that's a good sign.
  8. Aug 16, 2018 at 6:11 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    That's good for stop and go I find that I don't have to hit the brakes as much do to the bogging. Braking suffered thoug.
  9. Aug 16, 2018 at 6:38 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Kings are not as expensive as people think they are.
    Icons have a lot of problems, they tend to leak and have terrible customer service. They have the most complain threads in this forum. They are also a digressive shock which a lot do not like. Most all other shocks are progressive.
    I would call Marie @HeadStrong Off-Road
    There are a ton of manufacturers;
    King
    ADS
    Fox
    Icon
    OME
    Toytec
    Bilstein
    And more.
    Do a search for people running 33s and 35s to get an idea of what they did.
    As others have said you will have to do some cutting, welding, hammering, and new UCA for adjustments
  10. Aug 16, 2018 at 12:54 PM
    Spencer402
    Spencer
    2016 taco trd
