Lift kit pro comp 6"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacohago, May 22, 2017.
  1. May 22, 2017 at 3:36 PM
    Tacohago
    Tacohago [OP] Well-Known Member
    Jake
    2009 Toyota Tacoma TRD
    ChadsPride likes this.
  2. May 22, 2017 at 3:38 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    What size tires do you plan to run? How will you use the truck??
  3. May 22, 2017 at 4:03 PM
    Tacohago
    Jake
    Im going to use it for work, going threw trails occasionally but it will be a daily driver and probably 35" but I'm wondering if this will lift my truck 6" in the rear and front end
  4. May 22, 2017 at 4:04 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    You have way better options than that
    Why 6"?
    txtaco87, ChemDawg and grdgz97 like this.
  5. May 22, 2017 at 4:25 PM
    Tacohago
    Jake
    This is pretty cheap though
  6. May 22, 2017 at 4:26 PM
    Tacohago
    Jake
    Only like 360 cad
  7. May 22, 2017 at 4:32 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    That's only the shocks, you will need the whole 6" drop bracket kit.
  8. May 22, 2017 at 4:33 PM
    ChadsPride
  9. May 22, 2017 at 4:34 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What he said. That kit is still missing vital, expensive components.
  10. May 22, 2017 at 4:50 PM
    Tacohago
    Jake
    Ahhh isee that's why it's so cheap damnit I was excited
  11. May 22, 2017 at 5:46 PM
    Tacohago
    Jake
  12. May 22, 2017 at 6:06 PM
    ChadsPride
    Man honestly, it's really not worth it buying a cheap lift.
    If you were to do that, just buy $50 pucks for the front and $20 blocks for the back.
    Or save.for Bilstiens all the way around and an AAL for starters
    txtaco87 and reefnfeef like this.
  13. May 22, 2017 at 7:56 PM
    Tacohago
    Jake
    Okayy so if you could recommend any lift what would it be?
  14. May 22, 2017 at 8:00 PM
    Texas T
    TX
    '14 T Force
    3" lift and 33's will give more ground clearance than a 6" drop bracket and 35's. A lot of guys here run Billstein 5100's and OME coils front and 5100's and add a leaf or dakars rear. You will need UCA's if you do a 3" lift.
    ChadsPride, txtaco87 and SocalOC like this.
  15. May 22, 2017 at 8:05 PM
    Tacohago
    Jake
    Would a 6" be harder on my truck? And if I where to get a 3" you would recommend the 5100s then?
  16. May 22, 2017 at 8:19 PM
    Texas T
    TX
    '14 T Force
    6 wouldn't be harder on the truck, I don't think, but you might want to regear with 35's. 5100's are a good affordable option. If you want to spend some money go with King or Fox coil overs.
  17. May 22, 2017 at 8:34 PM
    Tacohago
    Jake
    Okayy cool what are you running on your taco?
  18. May 22, 2017 at 8:38 PM
    Manwithoutaplan
    ID
    chad doesnt like this.
  19. May 22, 2017 at 8:38 PM
    Tacohago
    Jake
    No it doesn't seem like it
  20. May 22, 2017 at 8:40 PM
    Manwithoutaplan
    ID
    from personal experience with my 6 inch lift. Don't do it. It is hard to convert back if you want to get rid of it.
