Lift kit question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phuket, Jan 29, 2011.
  1. Jan 29, 2011 at 7:21 PM
    Phuket
    Phuket [OP] Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  2. Jan 30, 2011 at 11:34 AM
    ozark705
    ozark705 "f*#@ it, dude. let's go bowling"
    Mid-MO
    03 4x4 DBL Cab SR5
    Gray Wire mod, Deckplate Mod w/aFe dry filter, anti-axle wrap u-bolt mod, fog light mod, LED interior lighting mod, & seafoam enthusiast
    It is not a question as to which one is better, but which one(s) are best for your application. If you have no intentions of lifting in the rear (keepin' it stock), the best would be the 5125s (Sonny @ DSM will help selecting which 5125s you should use). But if you are planning on lifting the rear in the future, the 5100s in the rear will allow for 3" of lift. Thus, you may want to go with 5100s in case you ever decide to add lift. If you know that you are lifting the rear to a specific measurement (i.e. 2") you can still go with 5125s, but they would be specific to your lift height.
    My taco, I have 5100s all the way around, with the front 5100s set at the middle setting and stock suspension in the rear and it sits almost dead level. However, I may put a 1.5" AAL or 2" AAL in the rear and go with OME 881 or Eibach coils in the future. The 5100s in the rear will allow for me to increase the lift (up to 3") without changing shocks if I decide to do so at a later date.
    Hope this helps and good luck!
  3. Jan 30, 2011 at 11:47 AM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    That helped a lot! thank you very much!
