Lift Kit question
Discussion in 'Suspension' started by Bristow.907, May 19, 2011.
  1. May 19, 2011 at 5:07 PM
    Bristow.907
    Bristow.907 [OP] Well-Known Member
    Onterrible
    07 AC sr5
    Alrighty, I've got a completely bone stock 2007 access cab sr5. After browsing the net, there are so many damn lift kits, that I don't know where to start. As far as height goes, I'm a little in the air about that. I don't know if I want to jack it way up, or have it high enough that it's noticeable. What do you guys recommend? I'm new to lifting trucks so I don't know the first thing about it haha. I've seen some guys talking about 5100's? What is that exactly, how much is it, and what do I gain? If I don't decide to lift, what is the biggest rim and tire size I can get on the truck without doing anything to it?
  2. May 19, 2011 at 5:11 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
  3. May 19, 2011 at 5:30 PM
    Bristow.907
    Onterrible
    07 AC sr5
    Helped me out some, Would I have to put those UCA on after the lift? or is that just an accessory that people like to put in?
  4. May 19, 2011 at 5:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Start here
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
  5. May 19, 2011 at 5:36 PM
    OZ-T
    Peter North
    British Columbia
    Once you lift the front end over approx 2 1/2" , adding aftermarket UCA's allows for a proper wheel alignment .
    Aftermarket UCA's provide additional caster , which you will max out or run out of with the stock UCA's .
  6. May 19, 2011 at 5:51 PM
    Bristow.907
    Onterrible
    07 AC sr5
    Seems like some very very complex shit if you don't know a thing about it lol.
    If I didn't want to lift it high up in the air, what do you suggest that I do in order to get a bit larger of a tire?
  7. May 19, 2011 at 5:53 PM
    OZ-T
    Peter North
    British Columbia
    You can run 265/75/16 on stock suspension .
    In order to clear 285's , you need a 2 1/2" - 3" lift and some trimming of the inner fender .
  8. May 19, 2011 at 6:25 PM
    Bristow.907
    Onterrible
    07 AC sr5
    How big a rims can I fit on that tire?
  9. May 19, 2011 at 6:28 PM
    OZ-T
    Peter North
    British Columbia
    265/75/16 is a 16" rim
  10. May 19, 2011 at 7:55 PM
    OZ-T
    Peter North
    British Columbia
