Lift Kit questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by j_cyrus, Jun 6, 2009.
  1. Jun 6, 2009 at 2:45 PM
    j_cyrus
    j_cyrus [OP] Well-Known Member
    Rickman TN
    Hey guys, new to the forum, not so new to Toyota's. I've had a 92 and a 94 pickup. Just bought a 99 Limited Tacoma extended cab TRD. Just wanting to know some things about a lift. Is Daystar any good? I am looking to fit some 33's. Is 3.5" big enough to fit 33's?
    Are body lifts any good? Or would you prefer suspension lifts?
    What do I need to expect to pay for a good 3.5" lift? Any suggestions on where to order one from? Sorry about all of the questions, just looking for some answers.
    Thanks in advance,
    Jake
  2. Jun 6, 2009 at 2:53 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i reccomend procomp suspension lifts, with a front spacer and an add-a-leaf, if you can find a metal spacer
    3.5 inches should be enough to run 33's but you may have to trim a little bit
    i am not biased when it comes to lifts, with a suspension lift you can go ahead and replace things like brakes struts balljoints while you are in there if they are getting close to their time and i often do that, if you do that you will get a smooth ride still, maybe a lil rougher than stock but i didnt notice
    body lifts give a slighltly rougher ride and look ugly on some trucks, however they are easier than suspension lifts to install
    torsion bars (not a prollem for taco owners cause we use coil springs) i hate it when idiots tighten them up then complain to me why the ride crappily
    a good suspension lift can range from 150-500 struts and shocks bout 70 each ball joints bout 80 but all you are looking for is the lift kits these are things you may want to replace however if its gettin close to due time while you have your suspension taken apart
  3. Jun 6, 2009 at 5:15 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    you wont get 3.5 out of a coil spacer lift. you can get three at best and do a shackle block rear lift
  4. Jun 6, 2009 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Forget spacers. Spend a couple bucks more and get some 5100 Bilstiens, and some OME springs. That will give you 3" lift, and you wont break anything, or have a crappy ride.
  5. Jun 6, 2009 at 5:26 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    sorry 3 is highest i install with suspension over that is illegal in nc and i wont be held liable
  6. Jun 6, 2009 at 5:35 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    you can only lift 3 inches in NC?! thats crazyy.
    and to the Topics starter:
    i have an 02 prerunner i put 2.5 up front and 1.5 shackle in the rear.
    Im running 285/75r16 right now on Pro comp wheels with a 4.5" backspacing.
    285 is pretty much a 33" tire so heres what you need to look out for.
    #1, backspacing. are you going to use stock wheels? you may want to save up and get new wheels that will push the tire away from the UCA and Frame. My tires (General Grabber AT2) only rub the frame cuz the inside rounds a little so it doesnt hit UCA.
    This could be solved by using wheel spacers if u like your stock wheels. but be careful. some people are skeptical on using those if you wheel alot.
    #2 trimming needed? you will most likely have to remove your mudflaps and to be safe you should 'Pinch Weld Mod' your fronts. as well as remove rear mudflaps.
    the rear should fit 33s stock, because the wheels dont turn obviously. and more clearance back there.
    if you have any more questions hit me up, im sure im missing somehting and out trucks are similar to what you want/what i have done. :D
    hope this helps tho!
  7. Jun 6, 2009 at 6:13 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    legally thats all you can lift your suspension, depends where u live though, in my region noone cares but i know others that have been pulled for it
  8. Jun 6, 2009 at 6:15 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i have an unknown amount of lift on my 02...but its accomplished with Sway-A-Way coilovers and a 3 leaf AAL from Wheelers Offroad with Bil. 5125s in the rear...
    i run 33's no problem
  9. Jun 6, 2009 at 6:45 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Haha i like your style, just do whatever it takes to make the wheels fit.
  10. Jun 6, 2009 at 6:48 PM
    JimBeam
    JB
    2015 Tundra
    actually not exactly...i fit the tires to the lift...
    i only dont know...because i dont care...the lift came as a result of suspension upgrades...
