lift kit questions...
Discussion in 'Suspension' started by EmoSlayer, Aug 29, 2009.
  1. Aug 29, 2009 at 9:54 AM
    EmoSlayer
    EmoSlayer [OP] METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    I want to lift my truck 3" to fit 285/70/17's under it. I've done a lot of reading through this site and have found a ton of great info, but still have some questions...
    Here's what I plan on lifting.. 2009 DC TRD Sport
    I mostly drive highway but sometimes take it on light trails, no rock climbing here..
    I pretty much want to avoid spacers.. so here is an interesting lift I found..
    LIFT:
    would these other parts work in combo?
    RIMS:
    http://www.4wheelparts.com/Wheels/R...s=209&t_pt=100021&t_pl=100348&t_pn=PCW98-7883
    TIRES:
    http://www.tirerack.com/tires/tires...WMTRKOWL&vehicleSearch=false&fromCompare1=yes
    Is anyone running this lift? How does it ride? Will this cause the truck to wander on the road? This isn't a full spacer lift?? I think they are 1/4 or 1/2 inch spacers that come with it for the front. Would this lift be sufficent for the kind of driving I am doing? Will the rear end settle and sag over time? Would 285/70/17's fit with a 17x8 rim with 4.5" backspacing? If anyone has pics of this lift installed it would be greatly appreciated.
    I have access to a full car lift, how brutal would it be installing it myself? Would I need a spring compressor?
    What other affordable options would you guys suggest considering the type of driving I am doing?
    ps sorry for all the noob questions, but I am new to all of this
    THANKS FOR THE INFO!
  2. Aug 29, 2009 at 10:52 AM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    The set-up is great, but I would opt for a set of new shocks as the factory billys aren't up to the task with the lift. Get the complete OME set-up through toytec. I can't recommend them enough. The wheels and tires look good, do understand that you'll need to trim a bit of the fender liner so you don't rub.
    The install is very straight forward and easy with the right tools. You should be more than capable of doing the install in 4 hours or less by yourself. It took me 2 hours to do the whole lift myself, but I've worked on cars for quite some time now.
    Good luck and hope this helps!
    Kind Regards,
  3. Aug 29, 2009 at 11:03 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i dont think you need a lift to fit those tires but also if you want a lift get it. i dont got a lift and i run the same size tires your talkin about on stock rims
  4. Aug 29, 2009 at 11:19 AM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    thanks for the quick responses!
    so is this the kit you recommend?
    I won't need anything else then? no uca's or anything else? If I bought this kit is it pretty straight forward for install?? I would probably run my stock rims and tires for now just to get my money's worth out of the tires, would this look stupid lifted? I'm having a really hard time deciding with what rims/tires combo to go with, the truck is black, don't know if i want to go all black or get chrome rims, 17s or 16s....
    also one more question.. where can i get this grille, it looks disgustingly awesome
    http://www.tacomaworld.com/gallery/showphoto.php/photo/29399/cat/500
    thanks again for the replies!!!
  5. Aug 29, 2009 at 11:22 AM
    FloridaFeMan
    FloridaFeMan Well-Known Member
    Southwest Florida
    '10 FJ Cruiser 4x4, '09 Tacoma TRD DC Sport
    Take another look at the wheel you selected. Your truck has 6 lugnuts and it looks like that wheel only has 5.
  6. Aug 29, 2009 at 12:22 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    ya that's just their stock photo its 6 on 5.5
  7. Aug 29, 2009 at 12:26 PM
    FloridaFeMan
    Southwest Florida
    That wheel looks pretty sharp. I am contemplating that same lift. It's either the OME or 5100 Bilstein's front and rear with AAL. We'll see. I am also gonna look into powdercoating my stock sport alloys.
  8. Aug 29, 2009 at 12:54 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    I thought of doing that too and powdercoating, I got a quote from a guy and he ball parked it at 100$ a wheel, which is outrageous, new rims would be cheaper! but another downside of keeping the sport rims and putting 285s on you would need to install spacers as well, at least that's what i was told
    anybody runnin 305/70/16's with a 3" lift?? How bad would they rub?
    these are pretty nice..
    http://www.4wheelparts.com/Tires/Mickey-Thompson-MTZ-Traditional-Radial.aspx?t_c=13&t_s=161&t_pt=100802&t_pl=6839&t_pn=M%2fT5265
