lift kit recommendations urgently needed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teaster28s, May 19, 2017.
most durable brand for lifting tacoma
  1. good choice
    3 vote(s)
    27.3%
  2. bad choice
    8 vote(s)
    72.7%
  1. May 19, 2017 at 10:06 AM
    teaster28s
    teaster28s [OP] Member
    Tea
    2013 red tacoma prerunner
    hello tacoma world!!
    i just got my baby a few months ago and i have many plans for her!! i wanna put in a 3-4 in lift kit. I've done alooooot of searching and reading up on different lifts, but i still don't know what to go with or which brand is the most durable. I'm mainly trying to go with struts or coils, none of those spacers. Heard terrible things about em...Right now im looking at Rough Country 4-inch Suspension Lift Kit for 05-15 Toyota Tacoma...any reviews for this? It's on ebay and it seems like it has all the works. If i go with this lift will i need new arm controls?
  2. May 19, 2017 at 10:11 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
  3. May 19, 2017 at 10:12 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Welcome to the forum. You will need UCAs for a 3-4" coilover lift.
    Your a prerunner so look at a set of spindles instead.
    ChadsPride and teaster28s[OP] like this.
  4. May 19, 2017 at 10:16 AM
    Pigpen
    Dan
    Northwest Montana
    Spindles and OME Dakar leaf springs like @ChadsPride
  5. May 19, 2017 at 10:18 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    X2
  6. May 19, 2017 at 10:25 AM
    teaster28s
    Tea
    thank you!ima check that out. i do take a lot of crazy dirt roads and go off-roading a bit so i just wanna make sure i get something durable, just making sure it comes with an all around level
    ChadsPride likes this.
  7. May 19, 2017 at 10:47 AM
    frejil
    frejil Well-Known Member
    Andrew
    2006 Prerunner
    Depo headlights
    Spindle lift for sure.
  8. May 19, 2017 at 10:56 AM
    teaster28s
    Tea
    i was looking at these but i cant find one with an all around level, do i need to purchase leafs for the back? or am i just not looking hard enough lol
  9. May 19, 2017 at 10:58 AM
    frejil
    Andrew
    2006 Prerunner
    Depo headlights
    Yeah you're going to need to find a way to lift the rear. There's a few ways like AAL's and blocks (oh god).
  10. May 19, 2017 at 11:12 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Spindles up front and Dakar leaf pack in the rear. You'll need to replace the shocks too.
    Check out @HeadStrong Off-Road...Marie is super helpful if you have questions and can steer you in the right direction.
  11. May 19, 2017 at 11:12 AM
    teaster28s
    Tea
    I would definitely avoid the blocks completely if possible. Im finding a few kits with the rear kits but its all blocks
  12. May 19, 2017 at 11:14 AM
    teaster28s
    Tea
    thank you! im finding some kits that include the shocks too im just wanting to avoid the blocks if i can
  13. May 19, 2017 at 11:15 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Don't feel like you need to be limited to a prepackaged kit.
  14. May 19, 2017 at 11:16 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Swap the blocks for Dakar leaf packs
    Call Marie at HeadStrong Offroad and tell her you want the 'ChadsPride Kit'
  15. May 19, 2017 at 11:16 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    don't buy a "kit" they usually cheap out some where. Like others said, talk to a dealer like headstrong, and they will put together a kit made from off the shelf, ala carte stuff that will work well together. Spindles, good shocks and a complete leaf pack since you plan on wheeling.
  16. May 19, 2017 at 11:20 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    From someone who has used rough country in the past, and had to put an additional $1,000 on top of the $1,000 "lift kit" to make it functional. i would stay away from rough country if you plan on using the truck as a truck.
  17. May 19, 2017 at 11:25 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Welcome to the forum!
    The spindles are the perfect affordable way to lift your PreRunner up the 4" without sacrificing the ride quality or factory geometry. If you have any questions let me know. (I have a Prerunner too :yay:)
  18. May 19, 2017 at 11:26 AM
    HeadStrong Off-Road
    Thank you so much @stickyTaco !
  19. May 19, 2017 at 11:27 AM
    HeadStrong Off-Road
    There are several ways to lift the rear of the truck. The best place to start is to measure your truck so you know how far off you are from back to front. I just pm'd you some information on doing so :)
  20. May 19, 2017 at 11:29 AM
    HeadStrong Off-Road
    Happy Friday Everyone :cheers:
    Pigpen, JimboAnz, Nicetacobro and 5 others like this.
