Lift Kit Recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cprfilms, Nov 10, 2024.
  1. Nov 10, 2024 at 5:41 AM
    cprfilms
    cprfilms [OP] New Member
    2011 Tacoma 4x4 Extended cab, long bed, grey
    Any lift kits recommendations for my 2011 Tacoma 4x4 extended cab, long bed to accept LT255/75/R17? I'm also thinking of installing wheel spacers to get the wheels to project out.
    I'm not looking to make a mud truck, but like to drive on trails. Thanks, Colin
  2. Nov 10, 2024 at 5:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    Use wheels with the correct specs and you shouldn't need any work for those tires to clear
    Poke can negatively impact trail driving (if they are tight trails especially).
    Lift won't create tire clearance. Nor will it raise the axle lines (lowest part of truck). It can improve approach and departure angles some if you have elevation changes where that matters.
    Just some things to noodle on.
  3. Nov 10, 2024 at 7:47 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    On a tacoma it's rarely a "Kit" but the few that are sold as a kit aren't very popular. Do the research on here, what you'll find more then likely is the "kit" will be made up piecemeal. Springs from one company, shocks from another and upper A arms for a 3rd vendor. A decent company that sells all those products can put together a "Kit" but it's just a collection of parts they assembled.
    jackn7 and Clearwater Bill like this.
  4. Nov 10, 2024 at 8:43 AM
    TacoTuesday1
    FL
    6112/5160 is minimum.
    I have HH and Icon RXT op3.
  5. Nov 11, 2024 at 3:13 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Spend some time over in the builds section and you’ll get a good idea.
    jackn7 likes this.
