Lift Kit Shopping Cart - Input requested
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BIDZ, Feb 23, 2015.
  1. Feb 23, 2015 at 8:23 AM
    BIDZ
    BIDZ [OP] Member
    Andy
    KY
    12' TRD Sport DCLB MGM
    Weathertechs, 13" AntennaX, Auto Vent Shades, 886 Reverse Light Mod, LED Bed Lights, Fatmat rear wall and doors, Painted Calipers Red, 20% tint all around, Blacked-out front emblem, Bilstein 5100s +885 + Deaver AAL, Goodyear Duratracs 265/65-17 on Fuel Vapors....
    Hello all,
    I'm shopping around on Wheeler's for a basic lift kit and before I buy I'd like someone to review my shopping cart and help me out if i'm missing anything. Any advice would be appreciated. fwiw I've read numerous threads here and I believe I've gathered enough to settle on the configuration, but if anyone can point out (from experience) why I should choose something different please let me know.
    Current cart:
    Bilstein 5100 Front strut set
    OME 2885 front coil set
    Bilstein Rear Shock set
    Wheeler's 1.5" add-a-leaf set
    Also considering (if needed):
    Toytec Diff Drop Kit
    OME leaf trim packer
    Will I have any need for a sway bar relocate kit and/or a rear brake extension bracket? I see that the toytec ultimate lift kit includes these.
    Are there any negative effects of such a kit that I might experience post lift (i.e., driveline vibes, UCA rubbing/bad angles, etc.)?
    Also, for reference I'm adding all this to a stock 2012 DCLB w/ TRD Sport configuration.
    Thanks in advance for any and all input!
  2. Feb 23, 2015 at 8:26 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Aftermarket UCAs are a good idea if you plan on setting your front billies at 2.5" or higher. Also, most on here will say that the diff drop kit does more harm than good.
  3. Feb 23, 2015 at 8:26 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Don't need the diff drop it can cause more harm than good. You will not need a sway bar relocate kit with this set up. Vibes are common and every vehicle experiences different ones. What setting are you setting the 5100's at? The will help with any other specifics
  4. Feb 23, 2015 at 8:27 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  5. Feb 23, 2015 at 8:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    get a toytec 1/4in top plate spacer for lean correction.
    No need for rear brake lines... the 5100's used in the rear offer no extra droop over the stock TRD shocks. but they are much better valved.
    No need for the diff drop, but you might need the ECGS front diff bushing.
    As far as the swaybar, you will not need the relocation bracket.... but just do yourself a favor, REMOVE THE SWAY BAR. the truck is going to ride so much better with out it.
  6. Feb 23, 2015 at 8:35 AM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    ^Beat me to it
  7. Feb 23, 2015 at 8:37 AM
    BIDZ
    BIDZ [OP] Member
    Andy
    KY
    Thanks for the quick replies and info. That is why I love this site!
    I'm only looking for a moderate lift, and will likely run the 5100's at a lower setting. Are saying my stock UCAs will be sufficient up to 2.5"? I may end up replacing them at a later time, but I'd rather not do it now unless its recommended with this setup.
  8. Feb 23, 2015 at 8:40 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Stock UCAs should be good for up to 2.5" of lift. Most people say the 5100s are too hard anyway when lifting more than 1.5"
  9. Feb 23, 2015 at 9:02 AM
    nd4spdbh
    SoCal
    that depends on coils.
    With the 885's your going to be setting it at 0 or .85 setting as you should already be getting some lift with the 885 coils if im not mistaken.
  10. Feb 23, 2015 at 1:22 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    You might consider 3 degree shims for the rear axles. Much easier to do them at the same time as the AAL.
  11. Feb 23, 2015 at 2:37 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    Might want to consider dropping the carrier bearing.
  12. Feb 23, 2015 at 2:43 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That was already posted in post #4 but good thought.
  13. Feb 23, 2015 at 2:44 PM
    geekhouse23
    :thumbsup:
  14. Feb 23, 2015 at 6:36 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    If you end up with the vibes, and you may not, worry about it then. May take sn ECGS bushing, may take a carrier bearing drop, or any number of other things that may or may not fix it :)
