Lift kit suggestions???
Discussion in 'Suspension' started by 2WDPARKER, Jun 23, 2014.
  1. Jun 23, 2014 at 1:42 PM
    2WDPARKER
    2WDPARKER [OP] Active Member
    Georgia
    SR5
    So i am ready to lift my 04 tacoma. I was gonna go with bilstien 5100 in the front and nothing in the back but now i want to go bigger a leveling kit that gives me 4 inches. Any suggestions on a good lift kit???
  2. Jun 23, 2014 at 1:50 PM
    Large
    Large Red
    :bananadead:
    Tons of options and an abundance of information, all you have to do is click the search button on the toolbar.
  3. Jun 23, 2014 at 1:52 PM
    Grakyn
    Grakyn Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    Deja vu........
  4. Jun 23, 2014 at 2:01 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    4"+ then your looking at drop bracket lift
  5. Jun 23, 2014 at 2:09 PM
    Mainmoe02
    Moe
    Austin, Texas
    If it's for looks then for a 1st gen 3" is enough and gives you the clearance needed to run 33" tires or 35" tires if you cut and trim. This is just my opinion so take it with a grain of salt. If you want to go above 3" then go with a SAS (solid axle swap) and you'll be sitting at about 4-6 inches of lift over stock, maybe more depending on the springs used. Like someone said above, there are tons of options, even long travel can get you 4". It all kinda depends what your gonna use it for, the quality you want, and how much $ you are willing to spend.
    Another option is go 3" suspension with coils and springs then add a 1" body lift. A slight body lift will be ok but I wouldn't recommend going higher.
  6. Jun 23, 2014 at 5:07 PM
    2WDPARKER
    Georgia
    SR5
    so is 3 inches of lift enough for 33s without having to cut out the trim?
  7. Jun 23, 2014 at 5:15 PM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
