Lift Kit / Tire's and Wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DavesTaco45, Oct 18, 2020.
  1. Oct 18, 2020 at 7:24 AM
    DavesTaco45
    DavesTaco45 [OP] New Member
    2010 Black Tacoma TRD OffRoad SR5 V6
    Hello all fellow Tacoma owners, I just bought my Tacoma a couple of weeks ago and I wanna do a 3 Inch lift, but I want retain my original struts so I was thinking about a block kit. I do wanna do some off-roading but I don't wanna go out and spend a fortune. Also want one that has a transfer case drop and maybe add a drive-shaft drop too? What do you guys recommend I buy?
    Also what's a good wheel and tire combo, thinking about a 18 Inch wheel but I want to know what sort of offset is good for a 1 1/2 Inch fender poke?
    Any help/ links to other threads would be very appreciated, Thanks!
  2. Oct 18, 2020 at 7:27 AM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
  3. Oct 18, 2020 at 8:53 AM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Welcome to TW. If you're planning to do some off roading I would suggest not to use spacers and blocks to lift your truck specially at a 3" lift. If you check the for sale section and even on offerup or ebay you should be able to find a cheap suspension upgrade. Also check out the suspension and Wheels/tires section and you should find the answers to all your questions there. Goodluck
