Lift Kit. Will this one cause driveline vibration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, May 15, 2011.
  1. May 15, 2011 at 10:10 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum,
    Will this kit work on a Tacoma Double Cab without causing driveline issues? (Go to ebay & enter item #300553592446). I just want a mild lift kit without having to change drive shafts or any other parts. I am new to this & have never owned a truck before so any help with this will be appreciated.:)
  2. May 15, 2011 at 10:29 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Doubt anyone will know for sure, it seems to happen in some trucks and not others... I could be wrong but doesn't this happen most often in double cabs?
  3. May 15, 2011 at 10:32 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    DCSB
  4. May 15, 2011 at 11:03 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Dude I would not go with this kit. $165.00 plus shipping for some aluminum spacers and ubolts is way too much plus your ride will not be the greatest and run the risk of damaging other components if off roading with this setup. You could get bilstein 5100's for another $20.00 or so. and just buy an AAL for around $40.00-60.00.
  5. May 15, 2011 at 3:36 PM
    TAC1
    Miami, Florida
    Sorry for the noob question but what is an AAL?
  6. May 15, 2011 at 3:40 PM
    rizzo20
    rizzo20 Active Member
    Central PA
    TRD Off Road
    Ad A Leaf
  7. May 15, 2011 at 3:42 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    AAL = add a leaf
    Is an additional leaf spring that goes under the existing leaf pack with the arch facing down like the letter U. Most come with new center pins too b/c the old one will be too short.
  8. May 15, 2011 at 6:42 PM
    TAC1
    Miami, Florida
    Will I have drive-line vibration issue with the AAL?
  9. May 15, 2011 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No vibes in mine, and none in the other dbl. cabs I have put lifts on.....
