Lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tig3r_Bit, Jun 24, 2018.
  1. Jun 24, 2018 at 12:14 PM
    Tig3r_Bit
    Tig3r_Bit [OP] Well-Known Member
    2018 TRD OR 4x4
    I just want a 1 inch lift. Do they sell? What's a good brand? I don't want any crazy lift. Well 1 inch cause any problem on my truck? Thanks
  2. Jun 24, 2018 at 12:21 PM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    whats the purpose of just 1"?
    i mean, that wont even be noticeable or give you really much clearance at all.
    chances are is not going to cause you any issues....
    but frankly ide just do a body lift if thats all the lift i wanted
  3. Jun 24, 2018 at 12:23 PM
    doorsidedown
    doorsidedown Well-Known Member
    bilstein 5100’s are adjustable. Get an AAL for the rear
  4. Jun 24, 2018 at 12:27 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    I'm soo new to this. I don't know. Lol
  5. Jun 24, 2018 at 12:28 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Bilstein 5100's 2nd gen model at 1st notch .85" 3rd gen model 2nd notch .65" , 3rd notch 1.1"
  6. Jun 24, 2018 at 12:29 PM
    M-cameron
    2017 Tacoma
    i think the important thing is to figure out what you want.....and why you want it.
    if you are lifting to fit tires....or are you lifting just to lift (and thats fine too)
    do you plan for it to be a daily driver with mild off road use......or plan to do some serious off roading?
    Tig3r_Bit[OP] likes this.
  7. Jun 24, 2018 at 12:30 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    @M-cameron i don't want to run into any kind of problems. Just want something that will feel like a ride stock. I'm also just going to ride on my stock wheels. Maybe a little bigger tires in the future. That's all.
  8. Jun 24, 2018 at 12:32 PM
    na8rboy
    WI
    Search; 3rd Gen 5100's Now Available - In stock Ready to Ship. It explains all about 5100"
  9. Jun 24, 2018 at 12:34 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    I just want a lift. No off roading. Just daily driving. And where I live it snows a lot.
  10. Jun 24, 2018 at 12:37 PM
    M-cameron
    2017 Tacoma
    you can always fit larger tires on the stock suspension....and that will give you a little bit of a "lift".....
    any time you lift, you always run the risk of needing to replace the CV carrier bearing....thats about the only real problem youll have.
    a body lift will give you a slight bump for larger tires, and keep the ride stock
    i dont know of anyone that makes a 1" spacer lift for the front, so coilovers would be the route youd have to take for that.
    personally ide start with wheels and tires first, and see how you like the look without lifting, then lift afterwards
    Tig3r_Bit[QUOTED][OP] likes this.
  11. Jun 24, 2018 at 12:40 PM
    Tig3r_Bit
    2018 TRD OR 4x4
  12. Jun 24, 2018 at 12:43 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    Also u mention a body lift? What is a body lift?
  13. Jun 24, 2018 at 12:46 PM
    M-cameron
    2017 Tacoma
    instead of lifting the suspension....if lifts the cab off the frame.
    they are good for small lifts around 1" to get enough clearance for larger tires......i wouldnt body lift more than that though or they look goofy
    thatll give you the lifted look, but leave your factory suspension in place....plus they have the added benefit of being much cheaper.
  14. Jun 24, 2018 at 12:47 PM
    Shady Rascal
    Shady Rascal Well-Known Member
    The South
    '17 TRD OR
    Pro Grille TRD Wheels Falken 265/70-17 Headstrong 1" Front Spacers OEM Mudflaps Black Bumper Ends OEM Bed Mat
  15. Jun 24, 2018 at 12:48 PM
    na8rboy
    WI
    They do make a 1/2" top plate spacer, which will get you a 1" lift. I wouldn't do it on my truck. 5100's are cheap enough to do instead.
    I'm at 1-1/2" front and 2" back 15TRD Pro suspension. I did diff drop and have no problems at all. CV angles stayed same as before lift, also did carrier bear drop, because of add 2" lift in back. A lot of people bash on diff drop, say it does nothing. Not my experience, like mention everything stay in factory spec's with it, and NO Problems.
    If you do 5100's and you mention it snow a lot in your area. Treat them with clear, or SharkHide. Salt makes them corrode fast.
  16. Jun 24, 2018 at 12:48 PM
    doorsidedown
  17. Jun 24, 2018 at 12:56 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    I wouldn't mind just giving the front a 1inch lift. Cause if u look. The truck front it is slightly lower than the rear.
  18. Jun 24, 2018 at 12:59 PM
    M-cameron
    2017 Tacoma
    its supposed to be, all trucks have a rake to them, so when you load up the bed, it sits level.
    popping it up 1" in the front will make the truck sit level......but it will also squat in the rear if you load up the bed with anything significantly heavy
  19. Jun 24, 2018 at 1:01 PM
    Tig3r_Bit
    2018 TRD OR 4x4
  20. Jun 24, 2018 at 1:05 PM
    na8rboy
    WI
    Spot-on, 200lb will squat ass end an 1' with stock leaf's.
