Lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HunterT, Mar 21, 2019.
Best lift kit
  1. Anything
    50.0%
  2. Anything
    50.0%
  1. Mar 21, 2019 at 6:37 PM
    HunterT
    HunterT [OP] Active Member
    Hunter
    Tacoma
    what’s the best lift kit I can get for 13 tacoma 2wd maybe around 500 and not have to replace a lot of parts I was thinking of the rough country n3 strut kit and maybe a 2 coil spacer on top ??
    b_r_o likes this.
  2. Mar 21, 2019 at 6:42 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Maxtrac spindles and blocks (leaf packs if you got the coin)
    You'll need longer rear shocks too.
    b_r_o, Casper66 and Johnny DemonT like this.
  3. Mar 21, 2019 at 6:44 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Chad he said around $500 how much were the spindels? Shocks and blocks probably $200 + longer ubolts
    b_r_o and ChadsPride[QUOTED] like this.
  4. Mar 21, 2019 at 6:45 PM
    ChadsPride
    I'll change my vote to anything :rolleyes:
    HunterT[OP], Mully, Tacotj and 2 others like this.
  5. Mar 21, 2019 at 6:48 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Well I wasn't trying to be an ass I just thought you could offer some real world pricing to that. The option you offered was good but he needs to understand some prices of some good stuff compared to not so good stuff
  6. Mar 21, 2019 at 7:21 PM
    ChadsPride
    I know, sorry for the sarcasm. My suggestion will exceed his initial dollar amount. The spindles have gone up since I got them, not too sure on current pricing.
    b_r_o and Casper66[QUOTED] like this.
  7. Mar 21, 2019 at 8:18 PM
    revtune
    revtune Dreaming of a 4.7 Tacoma
    Houston
    2007 Tacoma DCLB 4x2 4.0
    5100 front struts set on top perch trd sport coils Spc upper control arms 5100 rear shocks toytec add a leaf 1 inch rear block Longer U-bolts 17x7 SR5 (2014) 4Runner Wheels p285/70/17 Falken At3w AFE Stage 2 si with volant ram scoop MAF Calibrator 4.30 gears Undercover bed cap Weathertech floor liners
    For around the $500 price point I would Lift the front using your stock coils with the bilstein 5100 part# 24-239370 set on top perch. If you can, I would lift the front first then measure and lift the rear accordingly. For the rear lift, long style add leafs are great. Blocks work perfectly fine up to 2 inches.
  8. Mar 21, 2019 at 8:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Can i change my vote later if i change my mind?
    ChadsPride likes this.
  9. Mar 21, 2019 at 8:23 PM
    revtune
    Houston
  10. Mar 22, 2019 at 6:32 AM
    HunterT
    Hunter
    Tacoma
  11. Mar 22, 2019 at 6:32 AM
    HunterT
    Hunter
    Tacoma
    Would I use my stock springs?
  12. Mar 22, 2019 at 7:53 AM
    revtune
    Houston
    Yes, use your front coil springs with the bilstein 5100’s. Also, you don’t have to put them on the top perch, you can choose whichever setting you want in conjunction with your current or future wheel/tire combo. I run them on the top clip with 17x9 on 295/70/17 tires. My front measurement from center of hub to bottom of fender flare is 23.5.
  13. Mar 22, 2019 at 7:57 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Save your money and go with something you will like. Doesn't pay to go cheap, because you will end up replacing it all with something better. Good luck and welcome to TW.
    HunterT[QUOTED][OP] and Casper66 like this.
  14. Mar 22, 2019 at 9:10 PM
    HunterT
    Hunter
    Tacoma
    Okay I might end up going with this. I went on there and looked and saw they had a 5inch could I still use my stock springs with that and would a 2 inch spacer be okay if I added that . Do they ride good or close to the factory ride ?
  15. Mar 23, 2019 at 4:41 AM
    revtune
    Houston
    How do you intend to use your truck once it’s lifted? I can tell you I’ve had incoil spacers and I’ve also run the ones above strut. I’m not going to bad mouth them, they have their uses. With that said, I would absolutely not recommend stacking lifts. Example: Rough country 5 inch lift + 2 inch coil spacer. If you want a 7 inch lift and have it be right, you’ll be hovering in the $2,000-$2,500 range. I love the way my truck rides. I don’t go off road, so it made zero sense to splurge on something I won’t use. Does it feel stock/factory? Hell no it doesn’t, but that’s ok. Just remember, any lift you choose is going to change the ride quality and adding larger heavier tires will change it more so. The Bilstein 5100’s are a nice compromise lift without breaking the bank:thumbsup:
    christian06 likes this.
  16. Mar 23, 2019 at 6:13 PM
    HunterT
    Hunter
    Tacoma
    It’s gonna be. Pavement princess you could say just want a lift to clear 33’s and look clean nothing to high or fancy. Do you think the bilsteins 2.5 inch would be good or the 5inch and if I got the 5inch would I use my stock spring for that. And if I do get this will it be hard trying to get or make it hard for my truck to stay aline and not ruin my tires.
  17. Mar 23, 2019 at 9:07 PM
    revtune
    Houston
    HunterT[OP] and whatstcp like this.
  18. Mar 24, 2019 at 6:57 PM
    HunterT
    Hunter
    Tacoma
  19. Mar 24, 2019 at 7:28 PM
    HunterT
    Hunter
    Tacoma
    I think I’m gonna with the bilstein 5100s. Will I be able to clear 33x12.50r20with no offset and not scrub? And does it lift the bsck or do I need to get blocks? Also would it be bad to stack a 2 inch coil spacer I’m not gonna be off road just gonna be driving around town??
  20. Mar 24, 2019 at 8:23 PM
    revtune
    Houston
    5100’s are great. You will be happy. However, With that size tire you will most certainly have to trim plastic and do the cab mount chop so you don’t rub regardless of being on or offroad. I do not recommend combining a coil spacer with the 5100. Just Install the bilsteins on the top setting. Take measurements of the amount of lift you gained and then determine if you can or still want to run the wheel and tire size you mentioned. Blocks are fine for the back. In my opinion up to a 2 inch block will not affect the ride very much.
