Lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJoe2019, Jun 14, 2023.
  1. Jun 14, 2023 at 3:45 AM
    TacoJoe2019
    TacoJoe2019 [OP] Member
    Joe
    Cortlandt Manor NY
    2019 Toyota Tacoma TRD Sport Access can
    3.5 inch Rough Country Lift. KMC 17X9 -12 offset wheels (black) BF Goodrich KO2 285/70/17 tires Flowmaster outlaw extreme Axel dump exhaust. S & B cold air intake. AFE Silver bullet throttle body spacer. TRD Pro grill W/ raptor lights. Cali raised ditch lights. Cali raised hidden bumper light bar Cali raised compact light pods (bed mounted) Cali raised bed stiffeners Various exterior cosmetic touches
    Good morning Taco Peeps…. I need some advice. I have 19’ TRD Sport. I have it lifted with the Rough Country 3.5 kit. I want it higher. I run 33’s, and they still rub when I turn sharp. It was advertised that I’ll also level my truck but to me it doesn’t look level. Is there an option for adding something or am I better off swapping it out for a different kit?
    Any advice is appreciated !!
  2. Jun 14, 2023 at 4:03 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    These trucks don't like lifts above 2 inches. You're already at 3.5, and lifting more won't necessarily fix your rubbing issue. It's your truck, but I'd think long and hard.
    Chew, TacoJoe2019[OP] and 51Beets like this.
  3. Jun 14, 2023 at 4:03 AM
    McStudMuffin
    McStudMuffin Well-Known Member
    2018 TRD OR DCLB
    Bilstein 5100's, OME 888, Dakars, Leer Canopy
    Have you done the CMC? I see you have a -12 offset wheel, so you could try a wheel that does not stick out as much. I am lifted 3 inches with no rubbing issues with CMC and a -6 offset wheel. Just some suggestions I wanted to offer although I don't have any good suggestions for going above a 3 inch lift. I have read that going above a 3 inch lift gets quite a bit more complicated and expensive.
  4. Jun 14, 2023 at 6:34 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You’ve got it all wrong !!! Knowledge is power. Watch this. In fact, watch his videos regarding IFS lifts on you tube
    https://youtu.be/LAYGdcKSA3o. https://youtu.be/l1tTelhdEiM
    Chew and Speedfreak like this.
  5. Jun 14, 2023 at 6:55 AM
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    To go higher lots of cutting required. You’re pretty high already….If you don’t have the ECGS bushing in your front diff then it’s a ticking time bomb and your lift will grenade your front diff (needle bearings).(just trying to be helpful here not trying to scare you or persuade you)
    you can go 6” but like I said you’ll be cutting front cross member etc and it’s a lot of work, not hard just a lot to it.
  6. Jun 14, 2023 at 6:56 AM
    Halloween
    Toyotas a plenty
  7. Jun 14, 2023 at 9:13 AM
    TacoJoe2019
    Joe
    Cortlandt Manor NY
    Thank you everyone, so what about a smaller tire?
