Lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sanddune, Sep 26, 2023.
  1. Sep 26, 2023 at 12:32 PM
    sanddune
    sanddune [OP] Well-Known Member
    2020 Tacoma TRD Off-Road Sand Dune
    So I have a 2020 tacoma trd-off road sand dune color. I am just wanted to put a 3-4 inch lift on it and I gave heard good and bad things I am not looking to spend over 800 just any suggestions or information would help. (I have the trd rims just to help image the truck)
  2. Sep 26, 2023 at 12:39 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    What are you planning to do with the truck? Intended use? This will help us reccomend you a setup within your budget.
    Chew likes this.
  3. Sep 26, 2023 at 12:39 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    More than a 3 inch lift will require a drop bracket style lift (more than $800 and permanently removes part of your frame). Even at 3 inches you are drastically dropping the lifespan of your CVs. Use the search box up in the top right corner and you'll find a bzillion answers to your question.
    Here's something that was sticky'd on the 3rd gen forum that would probably be worth reading.
    https://www.tacomaworld.com/threads...2016-tacoma-presented-by-toytec-lifts.395798/
    Chew likes this.
  4. Sep 26, 2023 at 12:42 PM
    sanddune
    Yea man all I want to do is just make it look nice and I am in Florida so hurricane/ off-roading. Also don't want the huge gaps in between the tires and truck so looking at that too.
    I have heard a lot of good from bilstein stuff
  5. Sep 26, 2023 at 12:45 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  6. Sep 26, 2023 at 12:46 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    2wd...4wd?
    Chew likes this.
  7. Sep 26, 2023 at 12:49 PM
    sanddune
    4wd
  8. Sep 26, 2023 at 12:50 PM
    sanddune
  9. Sep 26, 2023 at 12:51 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    That’s what she said ^
    whatstcp, Tocamo, Shellshock and 4 others like this.
  10. Sep 26, 2023 at 12:54 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Being that you're 4wd the only proper options for over 3" of lift are outside of your budget. Have you considered staying under 3"?
    Chew and Clearwater Bill like this.
  11. Sep 26, 2023 at 12:55 PM
    YF_Ryan
    Kent, WA
    For $800 bucks though, probably not going to happen. Will you self install? You okay with cutting your frame's crossmember out?
    Chew likes this.
  12. Sep 26, 2023 at 12:56 PM
    sanddune
    No I really like the 3+ (lift kits) I can go up but not over 1000 because I still have to get the tires an all.
  13. Sep 26, 2023 at 12:57 PM
    sanddune
    No I don't think I will self
  14. Sep 26, 2023 at 12:57 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Save up and do it once IMO
    Burns likes this.
  15. Sep 26, 2023 at 12:58 PM
    sanddune
    Do you recommend any kits? This includes any height over 3+ inches for the kit
    71tattooguy[QUOTED] likes this.
  16. Sep 26, 2023 at 1:01 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    There are so many out there. Good ones are around 2” of lift. If you're not planning on off-roading then it doesn’t really matter what lift you do. Do research and check out threads about which lifts you might like. Ride quality etc. most of all have fun!!!
  17. Sep 26, 2023 at 1:01 PM
    YF_Ryan
    Kent, WA
    For $1000 you might be able to buy a cheap drop bracket kit, but will probably be that much again to pay someone to install it.
  18. Sep 26, 2023 at 1:03 PM
    sanddune
    Ok thank you. I am just wondering what is the major problem with something like this where not to expensive and still gives me the lift?
    (I am new to this please tell me everything)
    https://www.extremeterrain.com/skyj...-rear-lift-blocks-nitro-shocks-tc536stun.html
  19. Sep 26, 2023 at 1:04 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    At $800, a 2/1 space lift installed is what you’re budgeting.
    71tattooguy, jmneill and Strictlytoyz like this.
  20. Sep 26, 2023 at 1:05 PM
    sanddune
    I can go up to around 1000 if need to get the height
