Lift Kits
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Syd_P, Jan 31, 2016.
  1. Jan 31, 2016 at 9:11 AM
    Syd_P
    Syd_P [OP] New Member
    Syd
    2011 Tacoma Prerunner
    I want to lift my truck but I have no idea where to start. Im only looking to lift it a couple inches because i already have to pull myself up to get inside and i dont really want to have to use a ladder to get in but what do people recommend, 2 or 3in lift? Also, what are some good brands people have had good experiences with? If i lift it 2in am i going to have to get bigger tires and wheels right off the bat because my tires are still in great shape and id like to keep them if possible. Ive just got a million questions so if anyone could help id appreciate it greatly. Thanks!
  2. Jan 31, 2016 at 9:12 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    @HeadStrong Off-Road Marie will help you with everything you need. Figure out your budget and needs and go from there.
  3. Jan 31, 2016 at 9:15 AM
    Bumpr1080
    Bumpr1080 Well-Known Member
    Andy
    Tabernash, CO
    06 TRD Sport
    Icon, all pro and more....
    There's a million posts about that subject. Try browsing the suspension forum. Tons of info in there!
    Syd_P[OP] likes this.
  4. Jan 31, 2016 at 9:15 AM
    Syd_P
    Syd
    Awesome, thank you!
  5. Jan 31, 2016 at 1:22 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    In my lift thread you can see a 2.5" lift still running stock tires.
  6. Jan 31, 2016 at 1:30 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    So many choices, so much information! This is the place but unfortunately, there's no easy or one answer to that question until you read about it and have some inkling of all the permutations and combinations. The one early piece of advice that I can safely give is that budget wise, like everything else in life, cheap is not the way to go.
    shaunmang21 likes this.
  7. Feb 1, 2016 at 12:20 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    PM sent :D
  8. Feb 1, 2016 at 12:28 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Bout 2.66" up front, still on stockers
  9. Feb 1, 2016 at 12:31 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have OME 887's on 5100's up front for 3 inches of lift and rear ICON 2.0 Shocks with the ICON 1.5 inch Progressive AAL and Camburg Ball Joint type UCA's Rides sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet. And thanks to Marie for making it all happen
  10. Feb 1, 2016 at 12:48 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    There's everything from the sublime to the ridiculous available.....It's a popular thing to put the most extravegent, expensive, and highest tech parts known to man on a truck if you can afford it. While that's just fine, it's NOT always needed. There are multitudes of acceptable combinations in various budget levels. Most are MORE than adequate for the majority of us. Unless you plan on racing Baja, most of this stuff is BIG TIME over-kill.
    I've got along just fine with a 2" top plate spacer kit/1" blocks for the first 81,000 miles on my truck. Stock TRD OR shocks are beginning to wear down after all those miles, so I'm moving up a bit.
    I just ordered today, what is a great combination of parts that'll give me 2-1/2"+ of front lift, with adaptabilility to go a bit higher if I so choose. 2" in the rear, which I plan on upgrading later.....I'm doing Bilstein 5100's, OME 885's, Dever 2" AAL, assembled struts, delivered to my door for less than $750. I'll upgrade to a better rear leaf pack in a few months. I can always add a 1/2" top plate to the struts if I want to go past 2-1/2" in the front. Moral of the story? A decent suspension more than adequate for what I'll be doing, and at a reasonable price.
    See the above post from Headstrong......They're more'n helpful.
    HeadStrong Off-Road likes this.
