Lift kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hcjake4x4, May 18, 2025.
  1. May 18, 2025 at 7:10 AM
    Hcjake4x4
    Hcjake4x4 [OP] New Member
    Jake
    2019 Tacoma sr double cab
    Cold air intake Bumper Head unit Amp
    Hey! I’m new here, I have a 2019 sr double cab. I’m interested in getting a lift for my truck. Does anyone have any recommendations?
    I’m not sure if it’s something if attempt myself or not but I want to find the best options first. Any info or help would much appreciated
    Mully likes this.
  2. May 18, 2025 at 8:03 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    2" Bilstein 5100 is the best bang for the buck. (You can even use yours stock coils as per Bilstein). 1" block in the rear makes it a level 2/1" lift.
    If you want mild but good, you can set the 5100 @ 1" up front, and leave the rear stock, still perfectly leveling your truck.
  3. May 18, 2025 at 10:45 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    It really would be helpful if you told us how much lift you want, what area you live in/what type of 4-wheeling you intend to do, and what your budget is.
    Do you have a garage well-stocked with automotive tools? If so, then installing a lift should be fairly easy. If you don't, then you're probably better off having the lift installed at a shop.
    Answers to these will help people be able to make better rec's.
    Welcome to TW
    Chew and Mully like this.
  4. May 18, 2025 at 10:47 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Keep it stock, why? Because stock is cool.
    Good luck with your truck and welcome to TW.
  5. May 19, 2025 at 8:05 AM
    Diver_De_Taco
    Diver_De_Taco Well-Known Member
    ‘23 TRD OR
    I went with the 5100s with icon AAL using the stock coils, worlds better than the stock OR suspension.
