Lift left me with 3" of rake
Discussion in '1st Gen. Tacomas (1995-2004)' started by ERICtheENGR22, Jul 31, 2018.
  1. Jul 31, 2018 at 7:00 PM
    ERICtheENGR22
    ERICtheENGR22 [OP] Member
    Eric
    Sacramento
    2001 Tacoma Ext. Cab 4x4 TRD M/T
    Yeah I would agree that something seems off. Can anyone else chime in with 881's on what they have for a hub to fender measurement? Maybe I got 880's on accident somehow
  2. Jul 31, 2018 at 7:54 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    ‘06 AC TRD OR V6
    You can count the number of coil wraps to know exactly which coils you have.
  3. Jul 31, 2018 at 8:12 PM
    ERICtheENGR22
    Eric
    Sacramento
    I counted 10 coils. Couldn't find anything online definitively stating what that means. Could someone layout the differences in number of coils for myself and anyone else who may stumble upon this in the future
  4. Aug 1, 2018 at 6:38 AM
    eon_blue
    eon_blue got boost?
    Monrovia, CA
    2004 3.4l TRD 4x4 Tacoma XtraCab w/5 speed
    You have a double cab, v6 4x4 I assume? That's a lot of front end weight which is why the 881s didn't give you much lift. 4cyl, access cabs and 4x2s get more front end height out of them.
    boostedka likes this.
  5. Aug 1, 2018 at 8:19 AM
    boostedka
    James
    NM
    ‘06 AC TRD OR V6
    I did some looking around. It looks like just the 882s have any extra coil wrap from what could find. I could still be wrong though.
    Nice pointing that out. I hadn’t noticed the truck is a d-cab. That’s probably why the front is lower. Iirc, it’s usually recommended to go with 882 springs on 4wd d-cabs
  6. Aug 1, 2018 at 8:23 AM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    OME suspension package
    @eon_blue and @boostedka he's got it listed as a double cab but the first post pics are an extra cab.
    Here's my rake after install with 880s and dakars on my single cab, left me in a similar situation:
    It's definitely settling down after a few offroading trips, but I plan on loosening and re-torquing pretty much everything with the wheels on the ground.
  7. Aug 1, 2018 at 8:49 AM
    ERICtheENGR22
    Eric
    Sacramento
    MY* Truck is an extended cab V6 4x4 M/T TRD. Is there really any more weight in the front end of the double cab?
  8. Aug 1, 2018 at 8:54 AM
    tony2018
    tony2018 Well-Known Member
  9. Aug 1, 2018 at 9:23 AM
    boostedka
    James
    NM
    ‘06 AC TRD OR V6
    I think it’s a couple hundred pounds difference in the overall vehicle weight
    Years back on a ‘99 tacoma I had, I installed 882’s with Wheelers 5 pack leaf springs (1.5” Lift). This sat me almost perfectly level. This was an ext cab,V6, 4wd with no added weight other than TG sliders. It rode nice I thought, just a little firm in the rear.
  10. Aug 1, 2018 at 12:21 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 3", Tundra 17's, Cooper S/T Maxx 255/75-17, hitch w/ 7-pin, Leer cap, JVC head unit w/BT, LED lights
    pre and post measurements would have been ideal (though not many actually do it). this is a "lift kit" that will lift "over stock" not "already worn out springs" so what you are seeing is correct. the rear will sag more and sooner than the fronts ever will.
    this will just make the rear sag more and faster. the Dakar leaf pack is "standard" weight replacement springs with 2.5" of lift over stock
    add some sand bags or carry something in the back for a month or two. this will help cycle the springs and flatten them out. 881s are designed for no added weight. if you want a bumper, get 883s. my fronts have settled a total of about .5-.75 inch in 3 years. I'm still sitting over 2" higher than stock.
  11. Aug 5, 2018 at 8:04 PM
    ERICtheENGR22
    Eric
    Sacramento
    Loosened the suspension nuts and bolts and re-torqued with the rear end under load. Hub to fender measurement was now 24.5"
    Picked up 6 60 lb. bags of sand ($3.75 ea.) so I have 360 lbs. in the bed to help settle in the rear leaves
  12. Aug 5, 2018 at 8:28 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount
    Wouldn’t worry about getting the back down in a hurry. Time is on your side here. How’s the front doing? Did you figure out the lack of lift there?
  13. Aug 6, 2018 at 4:41 AM
    Clearwater Bill
    Clearwater Bill Retire from work, but not from life.
    Billy
    Clearwater Florida
    '13 5 lug base AC w/convenience package
    What was it before? I missed your pre re-do hub to fender somehow? IE, how much did that lower? Even if not much, it relieved the bind on the bushings which would shorten their lives.
    Also, when the rear goes down, the front normally rises a bit 'naturally'. Did you remeasure the front to see if it changed? Did you loosed/retorque the front as well?
    Agree with not having the need to haul sandbags. Let the springs work naturally for a while. Not that you are hurting anything. Other than MPG.
  14. Aug 10, 2018 at 10:07 AM
    ERICtheENGR22
    Eric
    Sacramento
    I have not loosened/re-torqued the front suspension, I plan on getting around to it. The rear was at 25" and after re-torquing with the suspension under load moved to 24.5".
    Currently I have 360 lbs. of sand in the bed and measure in at: rear 23", front 23" (from 22.5"). I will be removing the sand next week when I'm home
    As far as I can tell there are no issues with the front, it is just a product of the 881's. I don't have a stock hub to fender measurement to compare against. Also tried searching to see where others measured at with no success (ext cab, v6, 4x4 w/ 881's and stock bumpers)
    From here I am thinking I will go with a 1/2" top plate spacer and get it re-aligned. If anyone has any input on what could be the cause of the front end only measuring 22.5" or has measurements from their own lift please feel free to share
  15. Aug 10, 2018 at 10:13 AM
    #35
    Clearwater Bill
    Billy
    Clearwater Florida
    Keep in mind that if you are trying to level, you only add 1/2 of the F-R delta.
  16. Aug 10, 2018 at 10:23 AM
    #36
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    I have measurements from 02 double cab, stock bumpers on 265/75r16s. Dakars in back 883s up front
  17. Sep 1, 2018 at 8:31 AM
    #37
    ERICtheENGR22
    Eric
    Sacramento
    As of this morning i had 3" of rake (front hub to fender 22.75", rear hub to fender 25.75")
    I received a brand new set of OME 881's from ARB. I pulled the struts off of the truck and removed the spring from the assembly. When comparing the installed spring vs. the brand new 881 they look to be identical. This leads me to believe 881's plus dakar leaf pack = 3" of rake on MY truck.
    I would like to get the truck within an 1" of rake without removing any of the rear leafs (don't want to sacrifice ground clearance). Are 882's my best option? That spring being only 20mm longer than the 881 doesn't get me to my goal. Looking for suggestions!
  18. Sep 1, 2018 at 9:02 AM
    #38
    Grund72
    Grund72 Active Member
    SoCal/Camp Pendleton
    '03 V6 4x4 AC TRD
    I have an 03 AC V6 4x4. I put 881s w/bilstein 5100s and the Dakar leaf pack with an add-a-leaf in. This left me with an insane amount of rake as well. I also over torqued the rear springs at first, but even after fixing that, it didn't level my truck. I had to adjust the front shocks to the middle setting on the Bilsteins, which worked pretty well. Visually there's no rake left. This uses spring preload to raise the front end. In theory it should result in a more stiff ride, but I didn't notice a difference.
    If I were you, I'd go with different shocks instead of different springs. That's just me.
  19. Sep 1, 2018 at 9:17 AM
    #39
    Madjik_Man
    Boulder County
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    FWIW here are my measurements from center of hub to bottom of fender flare pre and post lift (1000 miles after install).
    881s, Dakar leafs, nitrosports all around. I have a V6 and stock bumpers, skids, etc. The only difference is that I have a topper on the bed.
    One thing I recommend is to drive around with some weight in the bed at all times. The ride with an empty bed is a bit stiff. With weight in the back it rides so much nicer.
    And one thing of note about the pre lift measurements: My suspension was completely shot.
    Before:
    Driver Front: 20 7/8"
    Driver Rear: 20 1/4"
    Passenger Front: 20 3/4"
    Passenger Rear: 20 1/4"
    After (1000 miles of driving):
    Driver Front: 22 3/4"
    Driver Rear: 24"
    Passenger Front: 22 7/8"
    Passenger Rear: 24"
