Lift Much?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jbgordon76, Aug 20, 2021.
  1. Aug 20, 2021 at 12:11 PM
    jbgordon76
    jbgordon76 [OP] Member
    '17 TRD off-road
    None yet
    Relocating to Beautiful Colorado! Of the plethora of trails out there, is it really necessary for a lifted truck and larger tires? Or, can my stock 3rd gen w/ stock sized all-terrains do just fine.
    I'm not looking to do massive rock-crawling or MOAB type craziness. Although I do like 'em crazy.
    Thoughts, Advice, Suggestions are always appreciated and welcome!
  2. Aug 20, 2021 at 12:14 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    The factory tires are definitely a weak point, so replacing those (even with the same size) would help out tremendously.
  3. Aug 20, 2021 at 12:18 PM
    Crosbaugh
    Crosbaugh Well-Known Member
    As stated, tires are a great start. From there, there is no reason to not get out there and see how you do. If you're running into clearance issues, you can re-address at that point. Pizza cutters (285/85/16 or 285/80/17) would give you a bit of height with little fuss.
    Junkhead and jbgordon76[OP] like this.
  4. Aug 20, 2021 at 12:22 PM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    I found moderate wheeling overwhelmed the OEM front shocks and also had some clearance issues. Some quality shocks, an AAL, 1.5” front/rear lift, and 265/75/16 tires really did the trick without breaking the bank or creating other issues. YMMV.
  5. Aug 20, 2021 at 12:23 PM
    jbgordon76
    '17 TRD off-road
    None yet
    285/85/16s any rubbing?
  6. Aug 20, 2021 at 12:26 PM
    AZ_J
    AZ_J Well-Known Member
    Ahwatukee, AZ
    2019 TRD OR 4x4 DCSB
    265/75r16, sliders, softopper, roof rack, 6112/5160's
    pizza cutters are 255 not 285 as typo-ed above
    AAL - Add a leaf, add another leaf to the leaf springs in the rear
    here in AZ, 265/75R16s are all I've ever needed to go anywhere.
    now getting rock sliders but only because I've seen too many t-bone cases where it looks like it'll save your life on here
    CalcityRenegade and Junkhead like this.
  7. Aug 20, 2021 at 12:43 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    265/75/16 Duratracs for the Win. Only reason to get a Lift is to put on bigger tires.
    Junkhead likes this.
  8. Aug 20, 2021 at 12:45 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    @jbgordon76, Best bang for the buck 2/1" Lift (no, not spacers), is the Bilstein 5100's, set @ 2" in front, and a 1" block in the rear. You got the OR model, so you can keep your rear OR shocks.
    71tattooguy likes this.
  9. Aug 20, 2021 at 1:05 PM
    jbgordon76
    '17 TRD off-road
    None yet
    Thoughts on Supercharger with all else stock?
    DanishTaco likes this.
  10. Aug 20, 2021 at 1:15 PM
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    I live in CO and put thousands of miles of trails, FS roads, and scree routes on my truck before lifting it. For most of that I had stock OR suspension and 265/70/16 General Grabber ATX P rated tires; never got a flat. There were plenty of sketchy situations that made me sweat a bit...eventually I did put on a lift and 33s to give a little more assurance. That said, move on out and hit the trails with what you have. Mod once you figure out your appetite for trail abuse.
  11. Aug 20, 2021 at 1:18 PM
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Junkhead and Tocamo like this.
