lift my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Willy4713, May 11, 2008.
  1. May 11, 2008 at 1:03 PM
    Willy4713
    Willy4713 [OP] Member
    University of Florida
    07' 4.0 SR5 4X4
    TSB, Heavy-duty Floor Mats, 3" Toytec lift, Bug-flector, Window guards, extra bed tie-downs
    The TSB thread was extremely helpful..i will do that before i lift my truck..are the bilstein shocks provided by the tsb 5100's..if not do i need to change them in order to accomodate the lift kit? I have gathered the bilstein shocks make for the best lifting method (only 2.5"), what else do i need to buy with them..coilovers and spacers??..i want ed to stay away from the add a leaf as i have heard it "sterns the ride"..
  2. May 11, 2008 at 6:06 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    University of Florida? Hell yeah man thats my dream school. I got a Gator hat on right now.
    The shocks that you get with the rear leaf spring TSB are just the TRD Bilstiens. They are not the 5100s. How much lift are you wanting? The 5100s only provide lift in the front. How much rear lift are you wanting?
  3. May 11, 2008 at 6:47 PM
    rick
    rick `
    5100s alone in the front.(on the top setting). leaf tsb in the rear, but get a set of 1" blocks for when the leaf pak settles, approx 3 months
  4. May 11, 2008 at 6:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, Blocks can induce or exacerbate "axel wrap" wich can lead to premature spring fatigue. Personally, I have a longer AAL with the TSB leaf packs and the ride is much better than it was when stock. :)
  5. May 11, 2008 at 6:58 PM
    Khaos
    Khaos Big Member
    Bryant
    Which AAL do you have? I heard that you have to trim the AAL to get them to fit with the TSB springs. Did you have to do any trimming??
  6. May 11, 2008 at 7:00 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
  7. May 11, 2008 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I really dont know. My wife got it for me from a custom shop near my house. I didnt have to trim it.
  8. May 12, 2008 at 6:44 AM
    Willy4713
    07' 4.0 SR5 4X4
    thanks to all of you for your input. I am wanting to lift approx 3"..What else will i need to acompany the 5100's on the front (extensions, joints, tire rods..etc)? Also, where can one buy the longer aal?
  9. May 12, 2008 at 10:54 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    if you want 5100's up front thats great, they are a much better ride, but you dont need them to go with a spacer lift. and do not set them to 2.5 inches and then add a spacer to get to 3", you are not suppose to use spacers with 5100's unless you have them set to the stock setting height. AAL is better than blocks, blocks cause axle wrap and can crack or break
