Lift on a Budget
Discussion in '1st Gen. Tacomas (1995-2004)' started by ttran, Jan 13, 2011.
  1. Jan 13, 2011 at 6:19 PM
    ttran
    ttran [OP] Expert Mallcrawler
    Tim
    Charlotte, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Decided to go with bilstein 5100's all the way around with toytec eibach coils in the front and ome dakar leafs in the back.
    Toytec Eibach coils (2) , bilstein 5100's (4), U-Bolts (4), Differential Drop Kit, Brake line extension, Old Man Emu Dakar Leaf Springs (2), Old Man Emu Bushing Set (2), Muffler Hanger
    Looking to install it this weekend
  2. Jan 16, 2011 at 2:23 AM
    ZRX1040
    ZRX1040 Member
    Upper Michigan
    SC D-Cab 4X4
    TRD SC/Hdrs/Exh, ARE Cap, Ivan Stewart Tundra wheels/BFG AT's
  3. Jan 16, 2011 at 3:24 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    if you go with the 5100's order from DSMS as they have free ship and and a better price on them as apposed to toytec you can also get the OME coils they offer. I ordered my 5100's from DSMS and the eibach coils from toytec and it all got here in about 4 days i believe but the shipping from toytec was a bit high, and for the rear im going to get the allpro 3" expo leafs cause mine are frowning, but if your leafs aren't sagged out then an 2" AAL would be fine.
    All in all the setup im going to run will set me back about 600-700!
  4. Jan 16, 2011 at 5:12 AM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    i'm looking for a mild lift so which leaf springs would accomodate a set of bilsteins with ome 882 springs nicely? for somewhere around a 2.5 lift?
  5. Jan 16, 2011 at 2:15 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Are the leafs you have now sagging at all? If not then you should not need a new leaf pack, just a 2" AAL
  6. Jan 16, 2011 at 2:47 PM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    My rear leafs are :pray:
  7. Jan 16, 2011 at 3:25 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Maybe you should save an extra couple hundred and buy a new leaf pack too. Maybe an OME complete kit.
  8. Jan 16, 2011 at 3:33 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Ha damn they are a bit worse than mine lol mine are just about perfectly fllat! but if you look at allpro's site they have the ones i am talking about in stock height and 3"-5" height., and also in regular and expo design which the expo's are made to handle a bit more weight for towing, but there are also other brands as well. just search for other threads about some, like dakar etc. did you decide what front lift your going to go with?
  9. Jan 16, 2011 at 3:49 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
  10. Jan 16, 2011 at 5:38 PM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    I want at least a 3 inch lift but I don't want a 6 inch DB so I was thinking of going with bilstein 5100's all the way around with eibach springs in the front. I did some searching and most people get at least 3 inches in the front with that set up. What would you guys recommend for the rear? And any input on my idea for my fronts? Thanks! Some links to your suggestions would be greatly appreciated
  11. Jan 16, 2011 at 5:43 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    The OME dakars give 2.25" so that would make it close to level with the 3" eibach springs. But from all the reading i've done on here and on ttora, the 5100s are too short if you lift the rear that much. They would be near their max, giving you only about an 1" of down travel. So you would probably need some 5125s for the rear with more travel. The 5125s also cause a little issue in that they will bottom out (longer travel=longer compressed length) unless you extend your bump stops to match.
    There are also a few guys on here running the eibach/dakar set up. They seem to like the lift/look/ride.
  12. Jan 16, 2011 at 5:47 PM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    Are the ome dakars a full leaf pack replacement? And hmm what shocks would work that won't bottom out for the rear?
  13. Jan 16, 2011 at 5:48 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Yes, The dakars are a full pack. The OME shocks work with the OME dakar leafs.....but they are more expensive
    ffr3064k is running eibach/dakars/5100s on his DC. You can pm him and ask how he likes it.
  14. Jan 16, 2011 at 6:04 PM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    Thanks for the help snowman! I'm really interested in that setup now. How difficult is it to extend my bumpstop and would I be needing new UCA's? It'll be right at 3 inches or a bit above so i'm not sure if that'll be pushing it with the stock uca's
  15. Jan 16, 2011 at 6:39 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Extended bump stops can be made in a few different ways depending on your skills or aftermarket bumpstops can be purchased from companies like Energy.
    As far as the UCAs go, the rule of thumb is they arent needed for 3" lift or less. Since ffr3064k is running that exact set up (5100s+eibachs), shooting him a PM might get some hands on experience answers.
  16. Jan 16, 2011 at 6:52 PM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    Just did that. Thanks!
  17. Jan 17, 2011 at 12:20 AM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    OME 881, Bilstein 5100 all around, icon 3leaf aal with a brand new stock 3 leaf pack, overload leaf in.
  18. Jan 17, 2011 at 6:32 AM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    slim, how much lift did you get from that set up?
  19. Jan 17, 2011 at 9:26 PM
    ttran
    Tim
    Charlotte, NC
    TRD Sport Prerunner
    just bought ome dakar leafs and eibach 3' lift coil springs. Going to buy 5100's for the front but can't decide between 5100's or 5125's for the rear. What should i get? and if i get the 5125, which size is recommended
  20. Jan 18, 2011 at 11:06 AM
    SlimDigg
    Calgary, AB
    My suspension was already about 9 years old, so I got about 3 inch all around.
