lift on an 08 2 wd prerunner sr5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awgg08, Jan 25, 2010.
  1. Jan 25, 2010 at 10:24 PM
    awgg08
    awgg08 [OP] Member
    Orange County
    08 TRD PreRunner
    hey guys i have been looking around for a a decent priced coil over lift for my two wheel drive prerunner i want something in the 3 to 6 range and was also wondering about the spindal lifts i honestly know very little and would like a little help..thanks in advance!!
  2. Jan 25, 2010 at 10:29 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i got the exact same truck and i have camburg spindles (4" lift) paired with toytec coilovers (0-3" lift). total chaos makes spindles for 3.5" lift.
    if you go 6" route as in a kit from fabtech or something like that your spending alot of money but that might be in your budget.
    i went my route because of the flexibilty i have with it. i want 4" of lift i got it! i want to go to 7" maybe 7.5" i can do that also!
  3. Jan 25, 2010 at 10:32 PM
    08pretaco
    Oliver
    az
    also camburg is 1000, total chaos is i think 1250. toytec coilovers 700 i think and there are so many people out there that make aftermarket coilovers setups its really your choice which one to go with.
    if you go above 2.5" using coilover setupd you will need a set of upper control arms in order to get wheel alignment into spec: lightracing, camburg, total chaos
  4. Jan 25, 2010 at 11:37 PM
    awgg08
    awgg08 [OP] Member
    Orange County
    08 TRD PreRunner
    cool thanks for the input i definately want to get the spindals and new coilovers but i dont know which one to get first and i know i have to get the u control arm with the coil over but do i need it with the spindal also?
  5. Jan 26, 2010 at 9:09 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    if you get the spindle you wont really need the new UCA. If I had the money I would get the spindles. I already have the Fox 2.0 coils and love them
