Lift on the cheap??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by praetorian300, Jun 28, 2017.
  1. Jun 28, 2017 at 8:22 PM
    praetorian300
    praetorian300 [OP] Well-Known Member
    There may be a thread on this already. If there is please link it. I'm new to this site so I'm not all too familiar but.....
    If I use 2"coil spacers up front, 1" AAL in the rear and Bilstien 5100's all around, is that an ok set up for a mall crawler and light, trail only, off road Tacoma?
    I really have no intention of wheeling this truck much if at all aside from a few fire trails and light camping.
  2. Jun 28, 2017 at 8:24 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Using blocks and 5100s up front is redundant. The 5100s will level it out on the highest setting with a 1" aal.
    bvbull200 and SAMSONITE88 like this.
  3. Jun 28, 2017 at 8:26 PM
    praetorian300
    How is the ride with the 5100's maxed out?
    I was worried that maxing them out would make the front too stiff?
  4. Jun 28, 2017 at 8:28 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    I cant answer that as i dont have experience with it, i have ome coils on my 5100s. Surely someone will come along soon and answer.
    What may help fine tune response/advice, what config do you have? Dcsb, dclb, access cab, reg cab, 4x4, prerunner, any other mods?
  5. Jun 28, 2017 at 9:02 PM
    Jed Dawg
    Jed Dawg Member
    2015 TRD Sport DCSB 4x4
    Adj 5100 Bilsteins stock coils 275 KO2's Ultra 17x8.5
    I have a 2015 TRD Sport DCSB 4x4 - I am running 5100's all around with front set on highest setting - after researching I decided to use my stock coils on my 5100's on front since I liked how the truck rode - I am very happy with the ride as it rides a little better than stock - many people run the 1" AAL but I decided to use a 1" block on the rear - I do very little 4 wheeling - I live in the hills at 5000 feet so we get a little snow each winter - hence the 4x4 - the 5100's on the highest setting using stock coils (no settling or break in on the stock coils) gave me 3 1/4" lift on the front (I measured before and after) - my truck sits 1/2" higher in front than rear which I like - I hope this helps you
    Jps_taco likes this.
  6. Jun 28, 2017 at 9:20 PM
    Jed Dawg
    Jed Dawg Member
    IMG_3355.jpg Here is a picture
  7. Jun 28, 2017 at 9:29 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Not comfortable.
    Kyitty likes this.
  8. Jun 28, 2017 at 10:22 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Agreed. I had 5100s at the second the highest setting and at first I enjoyed the stiffness. No more nose diving when I hit the brakes and the truck cornered flat. However, the stiffness also let's you feel every imperfection int he road and on long trips it was annoying. My 5100s are now at 0 with OME 887 coils for a 3in lift up front and I love it.
  9. Jun 28, 2017 at 10:33 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    If i hit bumps or anything with my 5100's the truck shook pretty bad. Almost like they didn't want to absorb any of the impact. Rode like that for a few years and then upgraded to fox 2.5 coilovers and the difference it night and day! Those same bumps, I barely notice them with the fox setup and that's with them maxed out at 3". I want to drop them 2" since I already have 4" of lift from the lift spindles. That should make it ride even better.
  10. Jun 30, 2017 at 4:25 PM
    praetorian300
    Thanks folks.
    So after reading the responses, here is what I want to do.
    Stock coils,
    2" spacer block up front
    5100 Shocks all around
    1" AAL in the back
    How does that sound for an inexpensive lift?
    I will have a cab high shell on a 2015 Xcab 4x4, V6, TRD,
  11. Jun 30, 2017 at 4:34 PM
    Forshee47
    Forshee47 Well-Known Member
    Trent
    North Carolina
    2015 Off-road DCSB 4x4
    If your already buying new shocks I would spend a little extra money and get ome 884 or 885 coils instead of the spacers. Only around $100 more for the coils from wheelers off-road than the spacer kit and IMO it's well worth the extra money
    Kyitty and Silverspool like this.
  12. Jun 30, 2017 at 4:41 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If you like the way your truck rides right now, a simple spacer lift front and back will do fine. Just keep in mind that a 2" spacer in the front will yield about 3" to 3.5" of lift since the strut is mounted to the lower control arm a little more than half way from the pivot point to the wheel.
    A rear spacer will get you exactly what you put in. In my opinion, the new shocks are not necessary if you like your current ride.
    You may want to add shock extenders to the rear. Toytech sells a set for about $15.
    For the occasional 'wheeler', a spacer lift will suit you fine will cost less than $200. Just buy a known brand. Avoid the generic ones on Amazon. Ask me how I know.....
  13. Jun 30, 2017 at 4:50 PM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    You can get a real nice lift with 5100s, OME coils, and an AAL for about $1000 installed, looks great and functions. I have OME 885 coils and a Deaver AAL, rides great.
    Edit:
    This would be about $450 cheaper if you do the install yourself (which is pretty simple), that was my original plan but I never got around to it, was worth the $450 to me to just have it done.
    NordidiroN, Silverspool and Forshee47 like this.
  14. Jun 30, 2017 at 5:34 PM
    Jps_taco
    Jps_taco Member
    Jesse
    2010 Taco
    2.5" Supreme suspensions lift
    Are you going to keep the 5100s at the lowest setting? I'm kind of in the same boat. I have a set of spacers and 5100s with stock coils. Not sure if want to run the 5100s at the lowest with the spacer or set them to the highest and not use a spacer.
  15. Jun 30, 2017 at 5:34 PM
    NordidiroN
    NordidiroN Well-Known Member
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Retrax MX Pro bedcover, Avid bumper gaurd, Predator step rails, Aux D rings, Door sill protectors
    This man speaks the truth. Wait and save a few more dollars to do it right.
    Forshee47 likes this.
  16. Jun 30, 2017 at 5:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    There's actually about 10. A day. Seriously.
    So here's a suggestion.
    Call Marie @HeadStrong Off-Road. Tell her your goals, let her suggest how to get there. If it costs more than you want, save your money and do it right the first time.
    You really won't regret the call.
  17. Jun 30, 2017 at 7:11 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    This.
    Never go cheap.
    Blocks/spacers are not suspension. If anything they will compress suspension and REDUCE travel.
  18. Jun 30, 2017 at 8:50 PM
    praetorian300
    How much travel do I need for mall crawling? :crapstorm:
  19. Jun 30, 2017 at 8:51 PM
    praetorian300
    I emailed her a while ago. She's good people. I just haven't made up my mind yet.
    HeadStrong Off-Road likes this.
  20. Jun 30, 2017 at 10:48 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    As much as the curb height? :notsure:
