Lift opinion
Discussion in 'Suspension' started by yota828, Feb 27, 2012.
  1. Feb 27, 2012 at 5:30 PM
    yota828
    yota828 [OP] Member
    LENOIR,NC
    03 Tacoma
    20% tint on front 5% on the rest, clear corners, half clear half red tail lights, painted grille and emblem, 3in ome coils(883), pro comp struts/shocks, toytec aal
    i have a 03 tacoma n jus ordered toytec 3in lift with coil/aal. also got the pro comp es9000 rear shocks n pro comp front struts. goin to run 33x12.50. what do yall think of set up n will the 33s fit?
  2. Feb 27, 2012 at 5:45 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    you'll probably need wheel spacers for the front. I have a 3 inch lift on my 04 with LT265/75R16 tires (32x10.50) and they rub a little on the inside of the front. so I would guess the 33x12.50 tires will rub a lot more.
  3. Feb 27, 2012 at 6:05 PM
    yota828
    yota828 [OP] Member
    LENOIR,NC
    03 Tacoma
    I'm runnin a 265 now with no lift. The coil is gonna make a 3in lift so don't need the spacers. O meant to add its a medium coil too
  4. Feb 27, 2012 at 6:06 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    He is saying you will need wheel spacers because the tire you want to run is 2" wider than what you have on there now.
  5. Feb 27, 2012 at 6:16 PM
    yota828
    yota828 [OP] Member
    LENOIR,NC
    03 Tacoma
    My bad. Miss read it. Thanks
