Lift option
Discussion in 'Suspension' started by TacomaRockStar, May 30, 2012.
  1. May 30, 2012 at 4:20 PM
    TacomaRockStar
    TacomaRockStar [OP] Well-Known Member
    LUCA
    Lacey Twp, NJ
    TRD Sport
    Toytec 3" lift with Bilstein all around, LR UCAs, AAL. Custom decals, short antenna, weathertech floor liners, Nfab Steps, Custom Emblem, LED lights all around, HID.
    2011 TRD sport. Looking to get 3" lift, can you guys direct me into a list of what to get or the proper way to do it.
    Thank you!
  2. May 30, 2012 at 4:28 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    What your budget?
  3. May 30, 2012 at 4:33 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Here's a link to keep you busy. This should help you narrow down what you need/want to ask.
    Frank
  4. May 30, 2012 at 4:33 PM
    TacomaRockStar
    LUCA
    Lacey Twp, NJ
    TRD Sport
    1000 or less? Not really sure where to start but I want it done right if it's 500 or 1000
  5. May 30, 2012 at 4:43 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I'd recommend heading over to Toytecs website and checking out either one of their kits with 5100's or the OME kit which they also sell. Both of these options are good setups for the money and will come in under $1000 (not including UCA's if you need to go aftermarket). Naturally there is much more higher end stuff you can get, but that will cost a lot more. Alternatively you can go with a cheaper kit like the Pro Comp or the cheapest route of going with a spacer lift (don't do this).
    Tons of people go with Toytec or OME though and I've been happy so far with my Toytec kit.
  6. May 30, 2012 at 4:54 PM
    TacomaRockStar
    LUCA
    Lacey Twp, NJ
    TRD Sport
    Do I need UCA's with either package of the 5100s?
  7. May 30, 2012 at 6:23 PM
    jtav2002
    Josh
    Reading, PA
    You may or may not. Some people can get their alignment close to spec without new UCA's, some need them. Personally, I'd recommend just going ahead and getting them. I got them right off the bat to avoid any potential issues. Light Racing are the most affordable ones and work fine. They look stock though so if you're going for aesthetics some of the more expensive brands look nicer with powder coating, logos, etc.
  8. May 30, 2012 at 6:57 PM
    TacomaRockStar
    LUCA
    Lacey Twp, NJ
    TRD Sport
    Thank you everyone. What do I need to pic in the option drop down menu and what's the difference between the 3 5100s packages the have?
  9. May 30, 2012 at 9:27 PM
    BulletToothTony
    Link to the website you looking at and i'll tell you...
  10. May 30, 2012 at 11:58 PM
    DevL
    DevL Well-Known Member
    Over 2.5" lift... you need uca.
  11. May 31, 2012 at 12:00 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  12. May 31, 2012 at 6:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A good 3" lift for a 4wd Tacoma under $1,000 is tough, you either need to increase your budget or go with a lower lift. At 3" of lift, you will need new UCA's which will run you $375 at a minimum and that doesn't leave you a lot left over for the suspension components.
    For 3" of lift, one of the best deals going is the OME kit with 885's, top plate spacers, Light Racing UCA's and an AAL for the rear. You can get the OME kit through either Toytec or Downsouth Motorsports and the control arms through the current Metaltech 4x4 group buy. Read through the link that ColtsTRD sent you on suspension, it should explain quite a bit and at least help narrow your search.
  13. May 31, 2012 at 9:33 AM
    TacomaRockStar
    LUCA
    Lacey Twp, NJ
    TRD Sport
  14. May 31, 2012 at 5:24 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Icon stage 2 kit with non-ext travel and keep the lift where Icon has them pre-set.....no UCA's will be needed! Best ride on/off road hands down!
    I've had a spacer lift and Toytec's and these are night and day difference! Your not paying much more BTW!
  15. May 31, 2012 at 5:29 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    PM Marco at DSM for the best deals....free shipping and 1 free re-valve!
