Lift options...
Discussion in 'Suspension' started by illmatyk, Jan 3, 2013.
  1. Jan 3, 2013 at 2:22 AM
    illmatyk
    illmatyk [OP] Well-Known Member
    Yigo,Guam
    2013 DCSB
  2. Jan 3, 2013 at 6:29 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    3" above is you want it for mild offroading and 6" for basically looks and larger tires.
  3. Jan 3, 2013 at 6:37 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2012 Lifted Tacoma Doublecab (SOLD)
    4" zone offroad suspension lift modified with Rcd bilstein front shocks w 1/2 spacer for 5.75" front lift and allpro expo leap pack with 2" block for 6" rear lift, extended length stainless brake lines front and rear, beefed taco carrier bearing drop brkt, 1.25 alum driveshaft spacer, avid lightbar powdercoated w 2 9" led lights, , amp research power steps, anderson aluminum drop hitch, ss grill insert w color matched grill, color matched door handles, color matched rear bumper, color matched pop n lock tailgate handle, 2012 sport mirrors added, color matched mustang hood scoop, borla ss exhaust, extang full tilt tonneau cover, windows tinted darker,oem roof rack, 2014 touch screen radio w navigation, infinity kappa speakers front and rear, rockford fosgate amp, 2 10" kicker subs, 2tone katzkin leather, hydro dipped interior parts, inalfa 925 power moonroof, lexus F sport shift knob
    I have the zone 4" which is the same thing as the bds. I also didn't get the kit with the coilovers. I went and added 5100's all around and also got the extended length brake lines. I think the kit is very well made and drives great. With me going with the bilsteins I can always adust them to get a lil more lift if I want and the 4" kit is actually 4.5. The only difference between the basic 4 and 6" kit is the rear blocks and in the front on the 6" kit they give you a spacer that goes between the top of the coil spring and top hat to give you the extra lift
  4. Jan 4, 2013 at 12:29 AM
    illmatyk
    Yigo,Guam
    2013 DCSB
  5. Jan 4, 2013 at 12:44 PM
    BORNWILDGUY
    Rich
    Florida
    I have heard that kit doesn't give you the best ride. If you wanna go that route you would be better going with 5100's, ome 885 coils or ebiachs and getting either a new leaf pack for rear or adding the icon 3 leaf progressive pack. Just my opinion.
  6. Jan 5, 2013 at 1:40 AM
    illmatyk
    Yigo,Guam
    2013 DCSB
    Thanks!
  7. Jan 5, 2013 at 1:42 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    prerunners do have the option of spindles for 4"
  8. Jan 5, 2013 at 1:59 AM
    BORNWILDGUY
    Rich
    Florida
    Only thing about the lift spindles is they push your front wheels out further. Thats the one reason I didn't go with them but they will give you a ride like stock and angles will be in check.
  9. Jan 5, 2013 at 2:08 PM
    illmatyk
    Yigo,Guam
    2013 DCSB
    Thanks, I will look into this as well.
    Since the front wheels will be further out, wouldn't it be possible to just add spacers to the rear wheels to have them go out further to match the fronts?
  10. Jan 5, 2013 at 2:21 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I have the first kit you posted. It's been on for a year and no complaints.
  11. Jan 6, 2013 at 12:51 AM
    illmatyk
    Yigo,Guam
    2013 DCSB
    Awesome! Thanks! That is the kit that i am leaning towards the most right now also!
