Lift options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JjBnew, Jul 7, 2023.
  1. Jul 7, 2023 at 4:42 PM
    JjBnew
    JjBnew [OP] New Member
    Hey guys, just bought a ‘22 sr5 with 7000km.
    looking for your guys suggestions..
    It has a 3/2 spacer and block level with diff drop already installed on it with stock shocks and UCA’s.
    should I just upgrade the uca’s and use all the life I can out of the stock suspension and upgrade later? Or upgrade to a full 3” lift kit and sell everything else.
    It’s my daily but I’m not far from decent trails every weekend.
    Can’t decide between rough country kit or OME kit.. significant price between the two. or get jba uca’s or ome uca’s and upgrade everything later.
    trying not to go completely broke on the build either lol
    All suggestions greatly appreciated! Thanks!
  2. Jul 7, 2023 at 4:50 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    Based on what I know (note: I've never used spacers) is that if you plan to offroad at all, ditch the spacers.
    Very limited knowledge of rough country or OME. I researched for about a year+ before I upgraded my suspension and went with Bilstein 6112 (front) and 5160 (rear) and Icon RXT, plus some other odds and ends (UCAs being one even though I could have gotten away without them from some info I found). Had a private mechanic do the install and bought product on my own. All in about $4,500. So not cheap. I subscribed to the by once, cry once mentality on this one.
    71tattooguy and Chew like this.
  3. Jul 7, 2023 at 6:46 PM
    JjBnew
    Thanks! That makes sense, I found a kit from them and ready lift.
    Would the bilstein 3” ready lift with the 6112 coil overs be a good option then in your opinion?
  4. Jul 7, 2023 at 7:08 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    spacer lifts are terrible on toyota ifs. bump stops are on lcas not shock so you bottom the shock out metal on metal without hitting the bumps causing harsh bottoming and possible damage. also overextends front end components at full droop. also stay away from rough country. their lift struts have the same problems. all they did was add the thickness of spacer lift to the shock body itself so its more or less an overpriced spacer lift.
    also no comment of what lift to get because theres already thousands (literally) of lift threads here to look through. depends on budget and use of truck.
    Maddog-51, Chew and JjBnew[OP] like this.
  5. Jul 10, 2023 at 9:50 AM
    BattleKat
    San Diego
    I don't know enough about the 3" ready lift to comment. As the last post states, there are dozens of threads on different options. It is a slog, but the best thing to do is pick a few options you think make sense for you, your budget, intended use, etc., and find threads on them. That will lead to more questions that you can ask on those threads. TW was very helpful to me when I was doing my research. Use those existing threads.
    JjBnew[QUOTED][OP] likes this.
  6. Jul 10, 2023 at 1:47 PM
    Tucker2020!
    Tucker2020! Well-Known Member
    Why do you want to replace your UCAs already? I would keep the stock UCAs. I was on stock UCAs up until I put 35s on the truck. 1st mod though - get rid of the spacers.
    I also replaced my stock shocks early on because I didn't like how the stock shocks road - too soft and the truck felt like it was floating when I hit a dip on the highway. It would bottom out easily on parking lot speed bumps too, wth. I originally went w/ the 5100s just to get beefier shocks to handle some offroad abuse - it served its purpose w/ Icon RXTs leafpacks. It fixed the issues I had w/ the stock shocks. I went w/ RXTs because I can over time add more leafs to handle more load. I also went w/ the 5100s because it gave me time to really figure out what I wanted to do w/ the truck and what I needed it to do w/o breaking the bank (< $800). I did the leafpack because the bed would squat with barely any weight in it.
    Honestly, I would use the truck first before doing any modifications. The main reason to make modifications is to address some shortcomings w/ the truck and you won't know what the shortcomings are until you drive the truck.
    When I bought my truck, I didn't have any plans of modifying it but as I drove it over the years I learned of shortcomings that I need to address (i.e., shocks, leafs, and gearing).
    JjBnew[OP] likes this.
  7. Jul 12, 2023 at 9:43 AM
    BattleKat
    San Diego
    My understanding is larger tires don't require new UCAs (perhaps they do for rubbing potential?)
    I thought the need for UCAs was with a 2" or higher lift. Mine was about 1.5" up front but to be safe I did the UCAs. Buy once, cry once, the truck was already going to be up on a lift.
  8. Jul 13, 2023 at 1:10 PM
    Tucker2020!
    UCAs really come in when it comes to fitting 35" tires or 33" tires mounted on wheels w/ the incorrect offset
    Junkhead likes this.
  9. Jul 13, 2023 at 1:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Or 33x10 fits no problem with stock UCAs.
  10. Jul 13, 2023 at 1:26 PM
    Dfpftw
    Dfpftw 1luv
    SoFLA
    SoFla
    Red DCLB Tacoma
    Trd intake stuff More intake stuff Kdmax pro 10.0 yayayaya
    If I run those on 1inch front or 1.5 front
    and 1.5 or 2 rear do I need to spend money on UCAs ?
  11. Jul 13, 2023 at 2:41 PM
    Matte Black burnt rust
    Matte Black burnt rust Well-Known Member
    2020 Tacoma TRD Off Road
    Check out Westscotts Design lift if you're not a hardcore off roader.
  12. Jul 13, 2023 at 5:10 PM
    Nate88cool
    Nate88cool Well-Known Member
    Nate
    NE Ohio
    2020 Tacoma TRD OR MT (and 2 jeeps!)
    None
    I was in the same boat. I went with Accutune and spoke with them for a bit and they built me a lift for my exact needs. Great customer service and I got exactly what I needed and very very pleased.
  13. Jul 16, 2023 at 11:40 AM
    BattleKat
    San Diego
    Sorry I never replied to this.
    At 1" or 1.5" no you don't "need" to. With that said, I did 1.5" to 2" up front and when I called around to places about doing an alignment on a lifted truck, their first two questions were 1. How much of a lift and 2. did you get new UCAs from stock (it helps with more adjustability).
    Again my mechanic said I could get away without new UCAs but that there were advantages to doing it. That is about the extent of my knowledge.
    Chew and Dfpftw[QUOTED] like this.
  14. Jul 16, 2023 at 2:25 PM
    taco562
    taco562 New Member
    Southern California
    2021 Tacoma TRD Off-Road 4WD
    I was considering the readylift version of the 6112. One thing to note is that they come with a readylift version of the top hat which is thicker than OEM and adds the extra .5-.75" needed to get the 3" lift. Does not come with rear shocks but instead comes with a 2" block. Good thing about the front shocks is that they come pre-assembled.
    I really wanted a package deal with all shocks, I ended up with the Eibach pro truck lift with a 1.5" AAL. Ended up with a 2.75" front (second notch) and 1.5" rear. Still running stock UCA, alignment specs are within range.
