Lift Options
Discussion in 'Suspension' started by deepseadiver, Apr 22, 2010.
  1. Apr 22, 2010 at 7:46 AM
    deepseadiver
    deepseadiver [OP] Well-Known Member
    william
    Norfolk, VA
    2010 prerunner
    Borla Exhaust Debadged AFE Pro Dry S Drop in
    want a small lift probably about 3 inch max so i dont have to do UCAs
    Option 1- rear tsb with front 5100's set at 1.75 and a 1.5 inch body lift
    Option 2- rear tsb with 5100's all around set at 2.5
    in the end i would like to run 285/70/17
  2. Apr 22, 2010 at 7:49 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    option 2.
    body lifts are bad, mkay
  3. Apr 22, 2010 at 8:17 AM
    deepseadiver
    william
    Norfolk, VA
    2010 prerunner
    i may not run the 285's i was also thinking about 265/70/17 with wheel spacers.
  4. Apr 22, 2010 at 9:13 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    mackey mmmmmmkayyyyyy
  5. Apr 22, 2010 at 9:17 AM
    Kmoney
    Kmoney Well-Known Member
    Kelly
    Bend, Oregon
    '17 DCSB TRD OR
    White dog
    Yeah... running 285's with a 2.5" lift will require some trimming, mmkaay?
    Oh, and body lifts are bad, real bad, nothin cool about body lifts, mmkaay.
    And just in case you don't know, the Bilsteins will only lift the front, so setting them at 2.5" will still look goofy if you only have the TSB springs in the rear, think about the Toytec AAL for TSB...
  6. Apr 22, 2010 at 11:45 AM
    deepseadiver
    william
    Norfolk, VA
    2010 prerunner
    i will probably just go with rear tsb, with the 5100's(just got them in the mail today from DSMS) set at 1.75 goodyear duratrac 265/70/17 with the spidertrax wheel spacers.
  7. Apr 22, 2010 at 11:47 AM
    sirsaechao
    Tim
    Commifornia
    You won't need wheel spacers.
  8. Apr 22, 2010 at 11:58 AM
    kenwolfe13
    kenwolfe13 New Member
    Ken
    Albuquerque, NM
    bull guard, TRD intake, TRD exhaust, clear L.E.D tail lights, H.I.D headlights, 3'' leveling kit lift,
    Stay away from the body lifts, there tacky and doesn't give you more clearance, i just lifts the chasis of the frame, i did a 3'' leveling kit that only set me back about 400 installed.. it's 3'' in the front, and and 1 1/2'' in the rear, i've been really satisfied and it raises it enough to put mudd tires on and looks better than stock
  9. Apr 24, 2010 at 12:09 PM
    deepseadiver
    william
    Norfolk, VA
    2010 prerunner
    i just think the wheel spacers give the truck a better look. I think i will be happy with the rear tsb and the front billies at 1.75 with the duratrac 265/70/17's Does anyone run this set up aand have pics?
