Lift or level?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ahallag88, Jun 17, 2019.
  1. Jun 17, 2019 at 6:33 AM
    ahallag88
    ahallag88 [OP] Member
    Austin
    Texas
    2018 TRD OffRoad Double Cab 4x4
    I have a 2018 trd off road, and have been considering giving a bit of a lift to it. I do occasional off roading, but it is pretty light. Mainly mud in the pasture while working. I am a fan of the ride quality the suspension gives right now and don’t want to effect that too much, but i want to give my truck a more aggressive look. What would be recommended?
  2. Jun 17, 2019 at 6:43 AM
    vickster83
    vickster83 Active Member
    Scott
    MS
    2011 5 lug DC
    wheels and tires. if you’re happy with the way it rides and handles now, i wouldn’t touch a thing on the suspension.
    ahallag88[OP] likes this.
  3. Jun 17, 2019 at 6:44 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Depends on how crazy you want to go big tires means more lift to clear cab mount or body
  4. Jun 17, 2019 at 9:49 AM
    Roddy13
    Roddy13 Well-Known Member
    Depends on if you want an instagram truck or not.
    Sounds like for you tires would be first.
    shane100700 and ahallag88[OP] like this.
  5. Jun 17, 2019 at 10:00 AM
    Wesintex
    Wesintex Well-Known Member
    2017 Blazing Blue Tacoma TRD OR
    255/85R16 Toyo Open Country MT, Customish bed rack, CB radio
    Tires should be your first choice then. You could run an off road tire in the 255/85R16 size. Will net you around 1-2" of height and give you a larger tire with better off road tread than stock tires. My stock tires measured right at 30" under load, put the Toyo 255/85R16 on there and they measured right at 33" under load. Net 1.5" lift and more aggressive tire look and performance for only the price of tires (no lift or wheels needed from stock). If you want a softer ride still, go with the Cooper ST MAXX or other Load C tire in this size. The Toyos in this size are heavy and stiff and will negatively impact on road ride (not substantially or unbearably in my opinion; but, noticeable).
  6. Jun 17, 2019 at 4:26 PM
    ahallag88
    Austin
    Texas
    Not really interested in an Instagram truck but something functional. Would a leveling kit be an option to get more clearance or is that going to effect ride?
  7. Jun 17, 2019 at 5:05 PM
    POPE125
    POPE125 Well-Known Member
    Im looking at doing the same thing Im not looking at doing a lift like the idea of a bigger tire . Using that 255/ 85/ r16 you won't have any issues with rubbing anything ?? 265/ 75/ r16 and the tire your talking about different ?
  8. Jun 17, 2019 at 5:18 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Just remember do it once save your save money in the long run buy once cry once
  9. Jun 18, 2019 at 8:02 AM
    Wesintex
    I do not have any issue with rubbing, on or off road. The catch here is if you change the wheel you may have rubbing. The stock wheel has the perfect offset and backspacing to allow the 255/85R16 to clear. There is a thread dedicated to this tire: https://www.tacomaworld.com/threads/the-skinny-on-skinny-tires.529656/
    The 255/85R16 coverts roughly to a 10" wide, 33" inch tall on a 16" wheel. The 265/75R16 is roughly 11" wide, 31.5" tall on a 16" wheel. These sizes will vary between manufacturer. For example, my Toyo MT 255/85R16 actual measurements are 10.2" wide, 33.5" tall (slightly larger than its competition in the same size). The stock tire measures approx. 10.7" wide and 30.6" tall. So, not noticeably skinnier than stock but significantly taller. The ratio for lift from a tire is 2:1 (tire size increase to amount of lift). Without even considering the load of the vehicle the Toyo's net approx. 3" taller tire and 1.5" of lift. Tire pressure, load rating, and weight of vehicle can impact how much the tire "shrinks" under pressure so the lift characteristics may be more or less when under load.
