Lift Ordered Install Needed DFW
Discussion in '3rd Gen. Builds (2016-2023)' started by DFA1, Dec 24, 2017.
  1. Dec 24, 2017 at 10:48 AM
    DFA1
    DFA1 [OP] Well-Known Member
    Brett
    Can anyone recommend a place in DFW to get my HeadStrong 3 lead aal installed? I ordered the fronts assembled, and think I can probably do the front, but the aal I'm def not comfortable doing it.
  2. Dec 24, 2017 at 10:57 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Dec 24, 2017 at 11:12 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The rear is pretty simple. If you’re comfortable bolting in the front assemblies then you’re plenty capable of doing the rear. All you do is jack up the rear diff, remove the leaf packs, put a C clamp on each side of the spring pack, remove the nut, insert the AALs, C clamp the pack back together, put nut back on, reinstall leaf packs, torque and roll.
