Lift ordered...now what?
Discussion in 'Suspension' started by VooDoo, Apr 25, 2011.
  1. Apr 25, 2011 at 10:53 AM
    VooDoo
    VooDoo [OP] More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    ok first off let me say i searched everywhere but could not find a definite answer to my question!
    Heres the specs:
    2006 Double cab long bed 4x2
    I currently have 5100's set at 1.75 in the front
    Stock suspension on the rear
    I ordered some used rear 5100 and toytec 2" (non-TSB) AAL from a member on here with ~7000 highway miles on them
    My questions:
    1. Would i need to raise my fronts up to 2.5? what would look better? (my stock leafs are sagging but not horribly)
    2. Will i need to get new U bolts and centering pins? (he did not include these when i bought the AAL from him)
    3. Because i'm a 4x2 i wont need axle shims, etc. will I?
    4. What are the odds of me needing UCA's?
    5. Would 265/75/16 tires look good?
    Thanks to all in advance!! :D
  2. Apr 25, 2011 at 11:08 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    bump! need help guys!
  3. Apr 25, 2011 at 11:10 AM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    I am not sure but I don't think you will need new UCA's since you are 2WD.
  4. Apr 25, 2011 at 11:15 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    thanks for the input!
  5. Apr 25, 2011 at 11:16 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I think it would look good with your fronts set to 2.5 with a 2 inch AAL. Install the AAL and see how it looks at 1.75. Switch it if you think .75 inches would look better.
    It's recommended to get new u bolts. Can't remember about the centering pins. I think those are needed also.
    You don't NEED shims or carrier bearing drop unless you develope vibrations. Install your AAL and see if u end up with drive line vibes.
    If you put your front 5100s to 2.5 you might want to consider new UCAs. You should be able to get away with an okay alignment tho still.
    265's should look good tho if u wanted u could fit 285's if u want to cut/trim and either get wheel spacers or wheels with backspacing of 4.5 or less ( thes is if u set front to 2.5)
  6. Apr 25, 2011 at 11:17 AM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Chill man lots of people work you might not get the perfect answer after 15 min.
    1. Do the back first if you don't like the rake change the Billy's to 2.5. Also remember everything is going to settle 1/4 of an inch or so. Use that when calculating on redoing the front.
    2. No you don't have to have new U bolts but many recomend them. You will need new centering pins. The stock ones are too short.
    3.Hopefully not. Do your lift if you get vibrations you will have to figure out what is causing them and address it then.
    4. At 1.75 probably not, at 2.5 probably. Again you can make the determination after you get everything settled.
    5. At 1.75 they will look good. (that is what I run) But at 2.5 you might wanna go bigger, but that opens a new can of worms. Just put the lift on and make your decision.
  7. Apr 25, 2011 at 11:21 AM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    Thanks guys!
  8. Apr 25, 2011 at 4:18 PM
    DevL
    DevL Well-Known Member
    4x4 or 4x2 has zero impact on the need or lack of need for axle shims (its all about rear lift height) or UCA (its all about front lift height and allignment).
