Lift porn, look what showed up today!
Discussion in 'Suspension' started by Sandfire, Mar 18, 2009.
  1. Mar 18, 2009 at 1:47 PM
    Sandfire
    Sandfire [OP] Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    Just arrived from Northridge Toyota! Okay, see if this works
  2. Mar 18, 2009 at 1:49 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Link FAIL.
  3. Mar 18, 2009 at 1:50 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    lol.....the links try to get me to sign into my hotmail.
  4. Mar 18, 2009 at 1:50 PM
    Sandfire
    southwest midwest
    Yeah, I guess, any ideas for me, I just copied and pasted:eek:
  5. Mar 18, 2009 at 1:51 PM
    jolayiv
    Jim
    New Bern NC
    Save the pics to your desktop and upload them to TW.
  6. Mar 18, 2009 at 1:52 PM
    Sandfire
    southwest midwest
    Standby
  7. Mar 18, 2009 at 1:56 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    <---- is eating some pork rhines
  8. Mar 18, 2009 at 1:57 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    was it the SAWS??? i hope so cuz they've been on back order and im hurting over here!
  9. Mar 18, 2009 at 2:04 PM
    Sandfire
    southwest midwest
    Got it fixed:)
  10. Mar 18, 2009 at 2:06 PM
    jolayiv
    Jim
    New Bern NC
    Very nice man! Why are you still on here? Go get that mess installed!
  11. Mar 18, 2009 at 2:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Im tellin ya....Those Emu's make some GOOD stuff!!!!
    Congrates! :)
  12. Mar 18, 2009 at 2:09 PM
    Sandfire
    southwest midwest
    I'm ordering the diff drop and AAL from toytec, not here yet:D
  13. Mar 18, 2009 at 2:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, when you go to install the N182's spray some WD40 on the bushing to help them slide in the lower shock mount. They are a tight fit. :)
  14. Mar 18, 2009 at 2:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh....And use Mobil 1 grease on the UCA bushings. Rub alot of grease on the bushings before you install the steel sleave, and put them into the UCA.
  15. Mar 18, 2009 at 2:13 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Nice setup. I want some OME shocks for mine. I keep hearing nothing but praise about their stuff
  16. Mar 18, 2009 at 2:14 PM
    Sandfire
    southwest midwest
    Thanks, any advice is greatly appreciated. I will be installing myself and am somewhat mechanically inclined, just in-experienced.
  17. Mar 18, 2009 at 2:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its pretty easy. The worst is getting the OEM UCA bolt out. Have an extra set of eyes helping you. And make sure you disco the air bag sensors from the body (above the wheel well, under the hood), they are black and yellow wire loom. should be 2 clips on each side. Also, there is a 10mm bolt holding a steel wire loom guide under the battery. Remove it., then, just a little bending, and the UCA bolt should come right out. You may have to chase it with a long 3/8" socket extension. :)
  18. Mar 18, 2009 at 2:20 PM
    Sandfire
    southwest midwest
    Do you have to bend something a little...? seems like I read that somewhere.
  19. Mar 18, 2009 at 2:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. Near the head of the UCA bolt, you need to bend the fender out of the way. Personally, I bend just a little bit, then, useing different size socket extensions, beat the bolt out with a hammer, from the back. You cant use big swings, as there is not alot of space, and on the driver side, up against the firewall, you have 3 fuel lines you need to be caurfull of. It sounds bad, but its easy. In fact....So easy a caveman can do it.........
    Sorry..I had to...I just saw it on TV...
  20. Mar 18, 2009 at 2:28 PM
    Sandfire
    southwest midwest
    HaHa! Sweet, if a caveman can do it I guess I'm in luck. Thanks for the suggestions, I will save this thread for when I install.:) Gotta go hit the gym real quick, later.....
