lift question for my 07 prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matta, Aug 19, 2014.
  1. Aug 19, 2014 at 1:24 PM
    Matta
    Matta [OP] Well-Known Member
    matt
    gilbert, sc
    2007 PreRunner SR5
    I just ordered these for my truck. 07 prerunner 2wd 6 lug:
    pair of bilstein 5100's for the front
    2.5" spacers for the front
    2.5" blocks and 1.5" AAL for the rear.
    wanting to go 33's on my 20" enkei wheels.
    how do you think this setup will do?
  2. Aug 19, 2014 at 2:34 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Why didn't you do spindles up front? Think they would have given 4 inch lift with a better ride than spacers.
  3. Aug 19, 2014 at 5:06 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Why did u get 5100 and spacers up front? Unless u didnt get the height adjustable, or if u plan on doing a horrible riding 5" lift that will quickly distroy every component on the front of ur truck?
    I see now that ur also doing a block and aal. Pretty sure ur gonna need new ucas and brake lines. I feel u would be happier with less lift. Like getting new springs up front in stead of spacers and settling for 3-3.5" with a 2.5" aal in back. I dont think ur gonna be happy getting that much lift mho.
  4. Aug 20, 2014 at 4:37 AM
    Matta
    matt
    gilbert, sc
    2007 PreRunner SR5
    I dont plan on maxing out the adjustment on the 5100s, should I just get lift springs with the 5100's? if so, what kind.
  5. Aug 20, 2014 at 4:58 AM
    ace96
    Western KY
    Do not use lift springs and spacers. If it were me, I would send that stuff back and get spindles since it's a prerunner. How much lift are you looking for?
  6. Aug 20, 2014 at 5:20 AM
    yota243
    E.J.
    north Alabama
  7. Aug 20, 2014 at 5:51 AM
    arock
    arock Well-Known Member
    MD
    2020 Cement TRD Off-Road
    I have an 08 PreRunner and I cant seem to make up my mind between 3 different kits, Toytec springs/billies with dakar rear leaf, full OME kit, or spindle/billies (no lift on the billies) with dakars). Any of these I'm sure everyone would recommend over spacers/blocks. First 2 options UCA's are def recommended which would be an extra cost. I'm not sure if anything else is needed or recommended to be done with the spindles and im also not sure the pros/cons of using the spindles vs a spring lift. Hopefully someone else can chime in on that.
  8. Aug 20, 2014 at 6:10 AM
    Matta
    matt
    gilbert, sc
    2007 PreRunner SR5
    Im pretty sure you would still need UCA's for the 4" maxtrac spindle lift.
    what kind of toytec springs are you talking about arock?
  9. Aug 20, 2014 at 6:14 AM
    arock
    MD
  10. Aug 20, 2014 at 6:19 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2023 TACOMA LIMITED DCLB LIFTED
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 5% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, LOCK WHEELS 17 X 9 -12 W 275/70R17 TOYO OPEN COUNTRY TIRES
    No You can use stock ucas with the lift spindles
  11. Aug 20, 2014 at 6:22 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    The maxtrac spindles do not require a new UCA. Only time a new UCA is required is when you want the extra travel it provides when using extended travel coilovers or you have so much lift (not provided by the spindle) that you can not get enough caster when getting your alignment done. New UCA's add some caster in to make alignment possible with lifts from either new lifting springs or preload on the springs to give you the lift.
    Just a little look into your future if you offroad with the lift you are trying to do up front.
  12. Aug 20, 2014 at 9:34 AM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    problem I have with the spindles is I can buy 4 5100 shocks and a aal for less than just the spindles you still have to buy a block or what ever for the rear
  13. Jan 14, 2015 at 5:26 PM
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    That's why I have decided to go with the Toytec 3 in. Lift with aal, about $200-300 less than just the spindles. Plus I don't really want the whole 4in. Of lift.
