LIFT QUESTION...HELPPPP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pngo121, Jun 2, 2011.
  1. Jun 2, 2011 at 10:07 PM
    pngo121
    pngo121 [OP] Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    whats going on tw members, i have a question. i currently have a pro comp add a leaf lift with front spacer but want a higher lift. the thing is i dont want a 6" lift because i dont really like the look. is the spacer and add a leaf a true 3" lift or will i get a more if i were to replace with coilovers?
  2. Jun 2, 2011 at 10:29 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    What size spacer and add a leaf do u have?
    3 inch spacer lift will give u the same as a 3 inch coilovers lift. 3 inches is 3 inches.
    Unless your spacer lift is less than 3 inches you won't gain any height from coilovers. (shouldn't go above 3 inches with any lift w/o drop bracket)
    You will benefit in the performance area with a set of coilovers or new springs to achieve your lift instead of spacers.
