Lift question
Discussion in 'Suspension' started by JR616, Nov 23, 2010.
  1. Nov 23, 2010 at 6:02 PM
    JR616
    JR616 [OP] Well-Known Member
    JAMES
    SOCAL
    06 double cab prerunner
    If I were to get toytec coils and set it to 3.5" and a toytec add a leaf kit would I need anything else for my lift kit?
  2. Nov 23, 2010 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welp...You dont want 3.5" lift from coils. THe ride would be horrible. For the lift, you want new shocks (front and rear), and springs. Dont go over 3" lift.
  3. Nov 23, 2010 at 7:06 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    And you'll likely need new UCA's to get your alignment right with 3" of lift.
  4. Nov 23, 2010 at 7:07 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    ya... UCA's... get 'em
  5. Nov 23, 2010 at 7:09 PM
    Dole
    Dole awesome
    4x4
    wicked flow
    i wouldnt go over three unless you wanna dump money into a drop bracket lift
  6. Nov 23, 2010 at 10:04 PM
    JR616
    JAMES
    SOCAL
    Ok I guess I'll get uca's and bilstien 5100 with eibach coils instead of the toytec coils. Is their any way to bump the truck up a little bit more than 3 inches to make 285/75 16 fit better?
  7. Nov 24, 2010 at 6:08 AM
    KPT
    09 Prerunner
    Prerunner or 4x4?
  8. Nov 24, 2010 at 8:56 AM
    JR616
    JAMES
    SOCAL
    prerunner
  9. Nov 24, 2010 at 9:45 AM
    KPT
    09 Prerunner
    You are in luck then. Lift spindles for the front will give you 4" of lift without changing any of your shocks, springs, UCA's, etc, and will ride just like stock.
    Camburg makes some good ones.
  10. Nov 24, 2010 at 11:47 AM
    JR616
    JAMES
    SOCAL
    how hard is it to make 33's fit with a 3 inch
  11. Nov 24, 2010 at 12:02 PM
    KPT
    09 Prerunner
    Not hard at all. That's the most popular combo on here. Requires some trimming and sometimes a cab mount chop.
  12. Nov 24, 2010 at 12:36 PM
    JR616
    JAMES
    SOCAL
    how hard is the cab mount chop? and will it be needed with kumho at kl78 if i barely ever hit the dirt?
  13. Nov 24, 2010 at 2:57 PM
    KPT
    09 Prerunner
    Search for "cab mount chop"..there are plenty of threads that cover it.
    The rubbing has nothing to do with going offroad, it rubs at full lock.
  14. Nov 24, 2010 at 4:51 PM
    JR616
    JAMES
    SOCAL
    How bad will it rub without the cab chop? Is it only bad when I'm turned all the way?
  15. Nov 24, 2010 at 9:54 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    If you get new wheels with a 4.5" Backspace or less. You wont rub the Cab mount. I think its only when offroading at full flex and turning is when you will rub it.
  16. Nov 24, 2010 at 11:31 PM
    JR616
    JAMES
    SOCAL
    alright cool thanks
  17. Nov 25, 2010 at 2:07 AM
    JR616
    JAMES
    SOCAL
    I meant the whole toytec coilover
  18. Nov 25, 2010 at 2:09 AM
    JR616
    JAMES
    SOCAL
    If I were to get the billies with the eibach coils what would I set them to to get 3 inches? The I think the coils themselves give 2 inches of lift
  19. Nov 25, 2010 at 7:07 AM
    KPT
    09 Prerunner
    Not recommended to set them above 0.85 when you are using eibach coils. That will give you around 2.5" of lift.
  20. Nov 25, 2010 at 9:36 AM
    JR616
    JAMES
    SOCAL
    should i use a spacer for the drivers side?
