Lift Question?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oat, Aug 26, 2011.
  1. Aug 26, 2011 at 9:29 PM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    Ok so forgive my ignorance since im still learning alot about trucks, but is it possible to put a lift on your tacoma if it has a front leveling kit on it already. I want to maybe do a 2" or 3".
  2. Aug 26, 2011 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Nope. Maybe a body lift, but you cant stack suspension lifts.
  3. Aug 26, 2011 at 9:32 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    The only time I've heard of stacked lifts was people with 6" dropped brackets stacking that with spacers.
  4. Aug 26, 2011 at 9:32 PM
    Qjake
    Qjake Just another Masshole
    Billy
    Massachusetts
    2016 Limited
    SCS Ray10's • 265/70/17 KO2's • Tonneau • Pop-n-lock • AVS Ventvisors • Weathertech • RedLine Hood struts • NoxLux Blackout Kit & Tailgate letters • 20% Tint • Cast OEM RunningBoards • Dechromed •
    yup but the leveling kit will have to go.
    search for "lifts" be prepared there's a ton of threads on lifts
    good luck:)
  5. Aug 26, 2011 at 9:35 PM
    Oat
    Florida
    2001 Prerunner
    So is it possible to remove the leveling kit and lift it more in the front, say 4 inches, then 3 inches in the back to level it out again?
  6. Aug 26, 2011 at 9:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    3" is about the most you can lift, unless you get a drop bracket lift.
  7. Aug 26, 2011 at 9:43 PM
    Oat
    Florida
    2001 Prerunner
    ^ Im assumming after i take the leveling kit out?
  8. Aug 26, 2011 at 9:49 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    not to hijack the thread, but im pretty sure this is one of the best ideas i have ever heard.
  9. Aug 26, 2011 at 9:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I meant you could add a body lift. Stacking body lifts is a horrible idea.
  10. Aug 26, 2011 at 9:51 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Look at the specs on most lifts. Generally speaking. The lift will level your truck out. So you wont have to worry about your truck not being level after the lift.
