Lift question
Discussion in '1st Gen. Tacomas (1995-2004)' started by dan476, May 7, 2012.
  1. May 7, 2012 at 2:24 PM
    dan476
    dan476 [OP] Well-Known Member
    Hey guys, I know there are million threads on here about lifting but I couldn't find an answer I am looking for.
    I have bought an 04 dbl cab that was already lifted. There is 2 3/4" block in the rear and my leaf springs look completely straight, in fact they almost have negative flex and thats with no load. Everytime I hit a bump I can hear leaf slap and its just not riding well.
    I have been looking at OME spring set, its rated at 2 1/4" lift. I was also thinking about buying a 1" lift shackle, just to bring it up to the same level where its riding now approx 3" lift.
    I do not use this truck for a lot of off-roading, mostly highway/city driving, and getting to and from my hunting area, after that all ATV.
    What are your thoughts?
  2. May 7, 2012 at 2:29 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Sounds like your leafs are shot. I would ditch the spacer and just 'spring' for a new set of leafs that will get you the desired lift. And most likely shocks will be needed.
  3. May 7, 2012 at 2:31 PM
    dan476
    I would like to keep my lift at around 3", and OME didn't seem to be too outrageous for a price, 189 a piece. I there any springs that will give me 3" lift without having to shackle it?
  4. May 7, 2012 at 4:12 PM
    dan476
    could anyone tell me if OME Dakar from Toytec with 1" lift shackle would be a good option for a double cab? Or should I look elsewere for other options.
  5. May 7, 2012 at 4:17 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    dakars are great, shackles will also work to help level; they'll get you more flex too
  6. May 7, 2012 at 4:28 PM
    dan476
    one more thing, I believe there are 3 versions of those leafs, I have a double cab, is there a specific one I should go with?
